VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
I vote to just move it to a more convenient location where we can turn it with our gloves on!!
I'm with Agman 57 on just moving it to a more convenient location.
Keep it simple.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I'm pretty sure the 2020 models will all have push button start now. Still will have a key to turn on/off which is odd, but I believe the kill switch can be used instead of key.
Dan
Dan
Joshua
- Apr 14, 2010
- Newfoundland
- 2018 Yamaha Sidewinder BTX LE 50TH
Dan
That is correct. My vote is make it like the 2020.
JayM
- Oct 29, 2018
- Pickering, ON
- 2017 Sidewinder R-TX SE
Relocate would be best I think, but would buy either solution
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Got some samples back and installed on a Viper today. New location is so much better. Rock's test harness fit perfect for a plug and play install. Do have to revise the leg with holes to drop them down farther so the nuts on inside clear the frogzkin intake vents found on the sidewinder cowl.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I am hoping the extension harness and the plug for the original location will be available separately from the bracket. I like the idea but I wouldn't want the bracket hanging off the side. I would rather drill a new hole for the key switch in the cowl area to the side of the handlebar riser area.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
What I was thinking. Much simpler and cleaner looking to just drill a hole there.I am hoping the extension harness and the plug for the original location will be available separately from the bracket. I like the idea but I wouldn't want the bracket hanging off the side. I would rather drill a new hole for the key switch in the cowl area to the side of the handlebar riser area.
IH8CROWS
- Jan 19, 2009
- Wisconsin
- 11 Apex
16 Apex
X2What I was thinking. Much simpler and cleaner looking to just drill a hole there.
snowfever27
- Jan 7, 2015
- Vermont
- 2015 Arctic Cat XF7000
2009 Yamaha Nytro XTX (sold)
2007 Yamaha Phazer FX (sold)
2005 Ski-Doo MZX 800 Adrenaline (sold)
2003 Arctic Cat F7 EFI (sold)
2007 Yamaha Attack
2009 Polaris 600 Dragon SP
- Vermont
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Not really an option on a winder due to intake ducting on underside.
Drilling hole is easy but also need the little notch so switch can’t spin. Felt many would be hesitant to attempt the cut out.
The cowl plastic is also too thin. Nut bottoms out on the locking nub before making contact with cowl.
snowfever27
- Jan 7, 2015
- Vermont
2007 Yamaha Attack
- Vermont
That all makes sense. I retract my earlier comment and would still be interested in the original key relocate kit. Power coated black please
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
I would have liked to put it right in cowl, just not ideal for installation.
Here's another idea. What does everyone think if I mounted it between the riser and gas cap? Could form up a nice bracket that attaches to the bottom riser bolts. No drilling, central location, and concealed.
snowfever27
- Jan 7, 2015
- Vermont
2007 Yamaha Attack
- Vermont
That would be awesome!
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Not a bad idea. Probably wouldn't work for me because I have my GEMS controller there on my MPI turbo Viper... but I would guess that it would work for most in that location.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
To answer your orig question i would offer harness and plug as an option for those that want to tackle mounting it in cowl.
- 18K
