hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
The tunnel protectors/coolers on the sidewinder are connected in the front via rubber hoses. These hoses are exposed in the tunnel, and proving to be somewhat vulnerable to tears and leaks from ice chunks/ rocks/ debris ect that find there way front in the tunnel.
I've spent some considerable time laying underneath the tunnel on my creeper just brainstorming ideas. The use of studs in a track really limits what I can do under the tunnel. I think I've got a concept that will work. The guard will attach utilizing the front foot well bar mounting bolt. A longer bolt would be needed, but its an easy switch out since the nut is easily accessible without removing the tank.
Below is a photo of my concept and a photo showing the bolt used to mount the guard. By no means is this final. Just sharing my progress so far.
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Looks great!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Travis....Very similar to what I was thinking.
I assume it extends forward, off the tube cooler, overtop of the rubber coolant hose. Does it completely cover it?
Secondly..... If you leave it short as shown, you will likely tear lugs and possibly even track clips when lugs contact the edge. I was thinking you could make it full length, all the way rearward to the stock tunnel protecters which are thicker/taller, so lugs could not tear.
What I would do then, is drill out the entire length, so snow dust can still aid in cooling the tube cooler.
Don did this exact same thing using sliders....he drilled them out, and were designed to be longer stud protectors, but since he extended it long it also helped coolant hose.
Dan
Dan
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
The lip is only 1/8" thick. Final design would have it sitting flush against the cooler and I would also chamfer the edge so there is no lip to catch the track lugs.
DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
Nice work Travis! I too like the short simplicity of just protecting the hoses.
Bt04f250
- Mar 6, 2017
- IL
- 2018 sidewinder xtx 137 high Vis ordered 2012 Polaris rush pro r Le
Looks nice so far! Should even work with my 1.75” track! Can’t wait till final product is available!
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
I picked up two sidewinders that were sold through insurance, and interestingly enough one of them was actually totaled from the torn hose and damaged tunnel around the hose. Finished stripping the other sidewinder yesterday so now i have a bare tunnel to work with and finalize something.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Travis , shoot me a PM as soon as you got your first ones made up brother, my sled is all apart as im installing cross shaft, idlers, and she is ready for the coolant hose protection.I picked up two sidewinders that were sold through insurance, and interestingly enough one of them was actually totaled from the torn hose and damaged tunnel around the hose. Finished stripping the other sidewinder yesterday so now i have a bare tunnel to work with and finalize something.
I like the idea of two mounting holes too. Great job as always.
Dan
hman4
- Sep 22, 2014
- 2010 Apex, 2002srx, 2000 srx
X2 Travis!!
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Will try my best to get it wrapped up next week!
TheMogulMogul
whupperofwhoops
Please let me know as well, I'll be pulling everything apart to do protectors and RR cross shaft.
scooterwj
I also want these once they are ready. TIA
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
great time to install this, when installing the cross shaft....Please let me know as well, I'll be pulling everything apart to do protectors and RR cross shaft.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Keep me posted as well.
Food for thought on the coolant hose protector. I like how you used duplicity with another bolt in the tunnel to mount the protector to - it would like make sense to have it anchored in 2 spots, even if a rivet was used as well as the the bolt for the stir ups to keep the bracket in line and keep it from pivoting on the single bolt.
MS
MS
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I have been talking bout this with Travis for awhile, final design will be ready soon hopefully.Keep me posted as well.
MS
- 51K
- 41K
- 32K
