mainedrummer
It would be nice if you could get a grease fitting on the assembly to get some fresh grease in from time to time.
Is this a change you're likely to make Val? Wouldn't want to do this mod then need to re-do it
- Jan 16, 2020
- Hamilton, On
- https://mainwaysolutions.ca
So This is something we can doo! Drilling in this location on a angle to the center of the two bushings with a 1/8 drill. Open up to 7/32 and tap the hole 1/4-28
Install a grease zerk and and Bob's Your Uncle.....The challenge will be where to drill for the grease zerk and have it accessible. I'm sure there are many ideas. I just haven't decided on one.
Without grease this pivot point will provide longevity, But grease is always better.
gpxsrx
What I did is drilled out added 18” grease hose and put outside. Never replaced plastic bushings but helped. Next summer I will do your brass kit. Very nice job.
- Jan 16, 2020
- Hamilton, On
What I did is drilled out added 18” grease hose and put outside. Never replaced plastic bushings but helped. Next summer I will do your brass kit. Very nice job.View attachment 157905
Nice work, Looks like you Have replaced a panel or two in your day as well
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
The spring clecos look good.
Did you add prc sealant to the parts also?
gpxsrx
No just rivetsThe spring clecos look good.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
New This Season: MYK08 Bell Crank Bushing Kit
These bushings are a huge improvement to the OEM plastic bushings
Puller Insert included.
Use a threaded rod and pull the new bushings in to place!!
Get rid of all that unnecessary slop the OEM bushings provide.
Check Us Out.
Just ordered up all three of your bushing kits for the sidewinder. Can't wait.
Do the bell crank bushing get grease zerts also?
- Jan 16, 2020
- Hamilton, On
My Test Mule has not returned to the stable so i can work on the grease zerk location,
I probably wont see it till June
I'll send a couple of fittings along with your kits, I have circled in red where i think a good location would be but i cannot be 100% sure until I see it
Your order will go out tomorrow afternoon Thank You
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Sounds good, thank you!
ksiesel
- Mar 25, 2016
- Indiana
- 2015 Viper RTX-DX
- Indiana
On post 63 here you can see where I located the grease fitting: https://ty4stroke.com/threads/cross-shaft-damage-and-repair-info-and-pics.145856/page-5#post-1481627
BTW, I have a new never used bell crank for sale that would go nicely with the new bronze bushings and grease fitting.
https://ty4stroke.com/threads/fs-new-sidewinder-viper-bellcrank-bushings.162901/
gpxsrx
gpxsrx
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Awesome products! Ill be in contact if we need any of these parts in the future
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Hey Val wouldn't it be much simpler to run a small hydraulic hose to a zerk mounted on a bracket in the nose behind the intercooler?
Just a thought!!!
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
You will be amazed how much free play is gone with the bell crank kit, on mine with sled on the lift if I grabbed both ski handles and moved the skis towards each other or push them away from each other there was quite a bit of play, now there’s nothing.Just ordered up all three of your bushing kits for the sidewinder. Can't wait.
- 35K
