1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Yes I angled the hole up slightly when I drilled so it would be positioned between both bushings.Is the location working out for you? And I'm assuming the grease fitting is standard size?
I measured the length of the bushing and went just above it and still needed to clear front panel with head of grease fitting when tightened.
I messaged Val and he sent grease fittings with the kit.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Cool thanks Tim.. I found the 1/4 28 grease fittings.. Pretty standard. Even found your drill tap combo on Amazon..Yes I angled the hole up slightly when I drilled so it would be positioned between both bushings.
REDLINE 1
Got my stainless rivets at ace hardware. Bought a cheap pneumatic rivet gunbat harbor freight that was worth its weight in goldLooking to do the Mainway products all the way around on new sled.. Getting ready as I have all the "stuff".. Anyone have a link for the rivets(stainless) you guys used after drilling out old ones? Also a link on the grease fitting.. Drilling and tapping for this fitting in Location shown by Inc2000? Wondering if anyone had any tips or details on this front end steering MOD.. Thanks
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I did the mainway products all the way around also. I would suggest buying his remove and install tool for the A arm pivot bushings.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Got it!I did the mainway products all the way around also. I would suggest buying his remove and install tool for the A arm pivot bushings.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Got a link by chance?OFT racing has them and Ulmer has them as well.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Email Val and he’ll send you the installation instructions with which SS rivets to use. I’ll have to dig through my notes to find it but I’m pretty sure 2 of them need to be longer.Looking to do the Mainway products all the way around on new sled.. Getting ready as I have all the "stuff".. Anyone have a link for the rivets(stainless) you guys used after drilling out old ones? Also a link on the grease fitting.. Drilling and tapping for this fitting in Location shown by Inc2000? Wondering if anyone had any tips or details on this front end steering MOD.. Thanks
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Thanks!Email Val and he’ll send you the installation instructions with which SS rivets to use. I’ll have to dig through my notes to find it but I’m pretty sure 2 of them need to be longer.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Replace the upper steering stem bushing with a billet one with brass bushing . Now would be a good time to do it since the stem is out of that bushing for this install. OFT racing has them and Ulmer has them as well.
THIS !
DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
Yes
DennyTuna
- Jan 28, 2017
- Ohio
OFT site is not up. But it's oftracing.com it says there closed for the summer. Prolly could call there.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Yea I looked on that site. It’s down. Ulmer has them. Just can’t add to cart. It says request a quote. I see what you mean about maybe upgrading while doing bell crank bushings.OFT site is not up. But it's oftracing.com it says there closed for the summer. Prolly could call there.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Thank you I kept wondering where the hell that piece in pic was so it has kept me from doing that bushing so far. That and I have enough other stuff to do lolI think the biggest challenge was to drill out the rivets to remove the Aluminum Brace.. I used stainless steel pop rivets to replace the rusty steel onesView attachment 156738 View attachment 156743
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
my experience with OFT is that he is not busy enough in the summer to run his site. I believe he has a seasonal full time job. He has always returned my calls and his site gets reactivated in the winter.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Did the bell crank bushings on 2022 Sidewinder. Not to bad of a job. Couple things I did.. I removed the aluminum steering rods by disconnecting them on each end and did not loosen the jam nuts. This helps to keep your tow out intact . Drilled out the 10 rivets and having a BIG rivet gun(long handles) helps with reinstalling rivets . I did drill and tap a grease fitting per Tim's measurement. One thing to be careful of is the voltage regulator has been moved on the 22. It is now located just above the brace that has the 10 rivets to be drilled out. Not a huge issue but something to be aware of. This bushing kit really takes the slop out. Thanks to 1nc2000 for the tips/pics .
- 35K
