snowmobilingjeff
- Nov 30, 2010
so i was riding the nice groomed trails in the u.p. last week when i blew my 1st belt with 300 miles on it....put a new one on and it lasted 28miles and blew....the cluthes are alligned so thats not the issude....the belt is blowing from the outside and not the inside.....looks like the belts are over heating....they were both straight from yamaha....i stay on the trails and do not boon dock....anyone else having belt issues ????
kopenytro
I had similar problems last year. I drill 10-12 holes into the plastic body panel cover just in front of the clutches and installed a 2 x 4 frog skin pre filter vent. I also drilled several holes in the plastic instrument panel piece that goes between the gauges and the handles bars. Over 1200 miles so far and no blown belts.
Also, I would try cleaning your clutches just to make sure there is no belt shrapnel in there.
Good luck
Good luck
snowmobilingjeff
- Nov 30, 2010
thank you i will check into it.....yamaha was kool about it when i called them...they offered to stand behind my nytro ....they advised me to take it in and have the dealer check the alignment anyway and the blown belt and they would cover it....he did state that i could have gotten a bad belt...also after 2nd ride with yamaha gloves that started to fray they stated they were under warranty for a year...and it wasnt a fight...way to go yamaha
NFLD-Nytro
If you're blowing a belt in 28 miles, or 300 miles, trail riding no less, you've got an issue that drilling holes in the side panel is not going to fix.
Zakre
If it were 28 miles i would still be driving to break it in, did you?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
kopenytro said:I had similar problems last year. I drill 10-12 holes into the plastic body panel cover just in front of the clutches and installed a 2 x 4 frog skin pre filter vent. I also drilled several holes in the plastic instrument panel piece that goes between the gauges and the handles bars. Over 1200 miles so far and no blown belts.
Good luck
X2, The clutches should be cleaned ever 500 miles.
basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
What do you guys use to clean your clutches?APEX 06 said:kopenytro said:I had similar problems last year. I drill 10-12 holes into the plastic body panel cover just in front of the clutches and installed a 2 x 4 frog skin pre filter vent. I also drilled several holes in the plastic instrument panel piece that goes between the gauges and the handles bars. Over 1200 miles so far and no blown belts.
Good luck
APEX 06
- Apr 30, 2009
- Sheboygan, WI
I use dawn dash soap and hot water.
kopenytro
Same thing (Dawn) and some 0000 steel wool on the clutch faces.
- 14K
