@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
k thksThunder doesn't reveal his rates... But I can tell you it's one the most stout springs I've handled
jlinstruth
- Aug 13, 2017
- Chamount, Ny
- 2018 Yamaha sidewinder ltx se
So what where results going other way with like a 37/33, for trail use
fourload
I put this spring in this weekend and wrapped it at 60. My hands still hurt!! Made my stock sled much more responsive with the stock 35degree helix. I was also wondering how different brand helixes measure out compared to the stock helix. Turk had a post years ago comparing different helixes (he measured them)and they were off by a couple of degrees compared to the stock helix. For example a Bender or Dalton may say 35 but they act much steeper or shallower than the stock helix. I miss Turks clutching posts. He helped me a lot with my RX1, APEX and Nytro.Thunder doesn't reveal his rates... But I can tell you it's one the most stout springs I've handled
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Agree with the different vendors' helixes. Rated angles will be slightly different from each other regardless of how similar they look. This is fact.
- Dec 4, 2004
- NS
- www.daltonindustries.com
A Dalton YSR 35 is EXACTLY the same angle as a straight 35 stock helix and rpm is the same.
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
I knew it wouldn't take long for Mr dalton to chime in. I'm not singling out anyone's brand just pointing out the fact that they're not all same. Testing is a must.
- Dec 4, 2004
- NS
That's correct (I was originally subscribed to this thread) ,
And I agree with you.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I just picked up ulmers stage 2 which is a spring and helix. Comparing helix angles and without knowing ulmers angle (all he told me is its a multi angle, not a reverse).
First pic is the stock 35 with daltons 35/39 reverse next to it.
Second pic is stock 35 with ulmers helix, quite the difference in angles.
DMCTurbo
- Nov 12, 2005
Ulmers spring next to TPs spring.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
show a pic of the weights....are the spring tangs 180 degrees apart?
@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
what torsion you have to be? 6-2?Ulmers spring next to TPs spring. View attachment 134645
DMCTurbo
- Nov 12, 2005
9-1, ulmer says its equivalent to stock spring at 3-3 when you compare with a fish scale.what torsion you have to be? 6-2?
@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
make sense and look like have more compression and no coil bind.9-1, ulmer says its equivalent to stock spring at 3-3 when you compare with a fish scale.
JPS
- Aug 23, 2014
- Clarks Summit, Pa
- 2018 sidewinder XTX, 2017 Viper XTX, 07 apex attack, 95 Vmax4
I also found the same results as you back in the day with 835 SRX running HeelX roller secondary 41/32 stiff spring, motor had plenty of grunt to accelerate and top end was amazingNo details needed, shallower angles have always work better 4 me. If you remember the old days back on the TY two stroke forums Turk or Srx Majic had tested some roller clutches. The conclusion was after 1:1 shift the clutches become very inefficient and belt tension drops off significantly. Best top speed was achieved with a 32 degree straight helix and heavy secondary spring. So I started testing the theory also and found I could get 5~6 mph more on a shallow helix and stiff spring. I had my SRX over 120 on Radar bone stock motor, killing ZRT 800’s on a wide open lake only clutching. Yea they accelerated faster but with some room I always reeled them in. Even button clutches gain a bit below 40 degrees. I believe I was running a 42/32 helix on a Haulk roller silver secondary spring.
Maybe this heavy orange secondary spring from TP is doing the trick and keeping the belt tighter?? Just my experience with helix angles is all I’m trying to convey.
JPS
- Aug 23, 2014
- Clarks Summit, Pa
I bought the same set up, waiting to give it a tryI ordered and installed the big venom kit along with the 33/35 helix and orange secondary spring based on you and Shagmans reports. Thank you for all your hard work. I'm sure I will be very pleased with the results.
