XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
Now that I have done it I have no doubt it will be very easy the next time. Splitting the caliper is by far the easiest way to remove the rotor and now I'm not worried about bleeding the brakes.i don’t know guys if they’re a way to plug the hose when you remove the caliper to prevent from leaking fluid?
stgdz
- Mar 27, 2021
- Buffalo MN
so is this a normal throw for a brake lever?
I can feel it start to build pressure about half way through the throw but can pull through it. Definitely feels spongy.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
No, my brake gets to parallel to the grip or just past parallel if I oh sh1t squeeze it. It doesn't get anywhere near the bar.
Fleecer
- Jun 13, 2014
- 2019 SRX
The easiest way to bleed brakes is to fill reservoir from the bottom bleeder using a lever actuated oiler.
I fill an oiler with brake fluid
Remove reservoir cap
Connnect rubber hose from oiler to bleeder screw
Crack open bleeder screw
Pump oil up through bleeder screw until reservoir is full.
Close bleeder screw
Put cap on reservoir.
Bam...nice hard lever!
Close bleeder screw
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
That’s the way that has worked best for me also.The easiest way to bleed brakes is to fill reservoir from the bottom bleeder using a lever actuated oiler.
Close bleeder screw
I just bought a cheap lever type oil can from Auto store and added some tubing to it to fit the bleeder screw. My Brake Bleeder dissapeared!
I usually give it a couple of conventional bleeding skirts after the bottom to top fill. And for really tough ones, try leaving the parking brake on overnight. Those steps should make it a one finger, very little throw, brake lever again.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Those reverse vacuum bleeders (pressure oilers) work well as they push air along until it reaches the reservoir, frankly the first time I saw someone use one I felt like an idiot for ever doing it any other way, it just makes a lot of sense.
stgdz
- Mar 27, 2021
- Buffalo MN
I've got a syringe that I have used on my ktm clutch that I can give a try tonight.
Last night I cranked the bars to put the lever in the highest position and put the parking brake on. We will see how it is later today.
stgdz
- Mar 27, 2021
- Buffalo MN
reverse bled a few times and can still pull it to the bar like it is in the video.
My other sleds hit a wall when pulling on the lever.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Were you using the syringe to pull from the master cylinder or pushing from the brake bleed screw?
stgdz
- Mar 27, 2021
- Buffalo MN
Reverse, and I could see the level rise.Were you using the syringe to pull from the master cylinder or pushing from the brake bleed screw?
Additionally I purged the air from the syringe before bleeding.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Its strange, its a pretty short run from the caliper to master cylinder. You do need enough velocity that any air can't simply stay stuck in place with fluid moving past it. I just had a quick look at my sled and I don't see any particularly high spots in the line where air could get trapped so I imagine it is somewhere in the caliper itself. You may have to orient the caliper so that the line to the master cylinder is at the high point, tap it a bit to get that bubble dislodged.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Make sure the master cylinder is level so air doesnt get trapped in there.
gerbes2
- Dec 9, 2017
- mn
- sidewinder
Used this vacuum pump multiple times on mine, work great.
stgdz
- Mar 27, 2021
- Buffalo MN
I have a compressor version of that.
It didn't work
It didn't work
If you do have to remove the brake caliper, put a bolt with sealing washers and nut through the banjo fitting as soon as you remove it to prevent draining.
