lhdriller
- Feb 17, 2016
- NW Ontario
- 03 Viper
2017 LTX-LE
I blew a belt a couple days ago with less than 1000km on sled. I was WOT running close to 9000rpm. Conditions were cold like -30C. When the belt blew it smashed a hole through the plastic. Clutches were a very warm but not hot. I could touch them.
I running TD powertrail with turboforce exhaust and Dalton weights. Hopefully this is a one time affair.
Ang suggestions to avoid this happening. Current belt is 8JP
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
lhdriller
- Feb 17, 2016
- NW Ontario
- 03 Viper
2017 LTX-LE
Yes for sure. Where did you get this?You should install a blown belt guard
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Barn of parts have them. There's a few different ones around.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Most guys know if they are gonna push these, they need a BOP Lower pan Guard, along with its top section.
Reading this site periodically is very important i find. I highly recommend it!
Straight out of my build thread: A whole whack of info.
https://ty4stroke.com/threads/my-rtx-le-50th-build-thread-let-the-mods-begin.149801/#post-1384039
Dan
Dan
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
TD sells a nice belly pan protector. Heavy duty piece.
MDGFLHR
- Dec 13, 2016
- Windsor Maine
- 2011 Apex SE
I just got my belly pan protector from BOP and since I need to take my primary off to make some adjustments can you drill the necessary holes with just the clutch removed? Thanks
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
I did it with the clutch on. You just need to watch your a arms when you drill throughI just got my belly pan protector from BOP and since I need to take my primary off to make some adjustments can you drill the necessary holes with just the clutch removed? Thanks
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I did this....see my build thread(SIG below)I just got my belly pan protector from BOP and since I need to take my primary off to make some adjustments can you drill the necessary holes with just the clutch removed? Thanks
dsimonRX1
- Dec 17, 2003
- Cascade,Ia
- www.american-iowa.com
Leave the foam in place underneath the protector?
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
YesLeave the foam in place underneath the protector?
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
I've seen bottom of side panel as well as behind protector with holes in them. Perhaps this needs to be re-engineered? Just sayin.
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
What does the belt guard look like?
34pontiac
- Nov 16, 2014
- WI
- Sidewinder
Apex
Search button...
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
- YOUTUBE
- FrozenTows1
Very helpful.Search button...
Tried. Only belly pan stuff. Should have said what does the OE belt guard look like After a blown belt.
- 11K
