sneakattak88
yep happen again!!! second time chain case goes on this thing, well took it apart tonight and found the chain tensionner to be snapped off, now i know why Yamaha has a bolt thru the case and the tensioner now, what a mess, will be getting the new style now!!
and while i have it apart the new Boivin skid is going in, I guess my best friend will be busy while im sitting on a cruise LOL,, have fun Kevin
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
What do you mean new style?
apltx08
Most of the time they get so HOT when riding at high sustained speeds they actully SUCK in the gasket and lose the oil and POW!!! I have a '08 and sucked mine in last year you have to keep a close eye on them...I change my oil every 1000kms and I've also made more grooves on dipstick to give more VENTING, after a long high speed run do the test, stop and get your hand down on the chaincase cover you can FRY an egg on it! be careful not to burn yourself
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
sneakattak88 said:now i know why Yamaha has a bolt thru the case and the tensioner now...
I think this is different than the gasket surface...
tko47
Ya I exploded my chaincase same way last year, the oil ran out but I had the three yr. warranty and Yami covered it, it's an 07 so I think I'm on my own now so I check every time I ride and/change it often. what are everyones thought on oil? I use Mobil 1 syn. 80/90
sneakattak88
the new style is a bolt going right thru the case, mine didnt have that, and not 100% sure but was also told they used a different material,,
can buid engines that are bullet prouf but cant cool down a chain case, or i burn up hyfax, oh the |Boivin plastic skid is going in this week also
can buid engines that are bullet prouf but cant cool down a chain case, or i burn up hyfax, oh the |Boivin plastic skid is going in this week alsoSimilar threads
- 7K
