brace for dished out tunnel?
rock doc
Saint John, NB Canada
Canada
2018 Sidewinder XTX SE. Previous 2011 Nytro xtx, 2016 Apex GT, 1998 Polaris Indy 600 xlt
hey gang
The top of the rear tunnel is dished out on my 141 XTX and the brace under the twilight is bent. I installed a new piece of angle but it did not hold. I have been trying to find a rear tunnel brace or top carrier. looked at the pro climb bracket. will this work? Any other options? most stiffeners only run down the sides of the tunnel.
I went with cr racing bumper and inside braces, I now hold a 20L plumbed in slip tank, no issues and I ride pretty hard on my 146 xtx. I also put in a stingray spring, I felt that a big cause of the buckling was from ice freezing and starting the buckle at the end of the running board and then bottoming out. With weight on the tunnel it simply bends.
that looks fantastic. where did you get it?
it was considering a similar option with kimpex. the last connect system seems ti move the weight from the middle to the side of the tunnel.
A bit hard on the eyes, but I can count on 300km easy without refueling
Powderkeg and blingfactory.
