I have had one sled have a split pad out of 50 or so I have serviced but other then that I wouldn't waste my money. The fear I have is if the brass would split and fall out they may take out the chain-case and the stock one mostly like would get chewed up.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Yikes! I hadn't considered that before changing my stock ones over to DMC. Now you have me thinking I should go back........... if the brass would split and fall out they may take out the chain-case and the stock one mostly like would get chewed up.
Sorry but it’s a good thought. Especially if other have seen brass ones break.Yikes! I hadn't considered that before changing my stock ones over to DMC. Now you have me thinking I should go back....
Not sidewinder but I have 28800mi on my Viper with original pads. One thing to watch other than TopGear bushing and Tensioner bolts is the rubber cushion between top reverse gears mine was disintegrated last season. Out of stock. Found a used one and put in. Something to look for that I have overlooked in past. Pull those two gears apart.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Yes I just replaced mine last season as well.Not sidewinder but I have 28800mi on my Viper with original pads. One thing to watch other than TopGear bushing and Tensioner bolts is the rubber cushion between top reverse gears mine was disintegrated last season. Out of stock. Found a used one and put in. Something to look for that I have overlooked in past. Pull those two gears apart.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Still on factory plastic from '17
Great catch! I never saw anyone mention that and I forgot too. The cushion shown in bottom gear.Yes I just replaced mine last season as well.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
No problem here with my stock pads on my 2017, but I do make sure that my top gear busing is good every season!
And as for the gear cushion, I can say that Ive only taken that apart but once, and that was when my sled was still pretty new, and my chain had rubbed and caused a bad wear spot on the internal post/nub! I had to tear completely apart to clean all of the metal deposits inside my chain case, gears and chain! Next season's maintenance I'll make sure to separate those two gears and take a peek! Thanks for the heads up!!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I had no issues with the stock pads.
I was on Hurricane web site buying top gear and chain a while back and put a set of brass pads in my bucket just because all the cool people were doing it. Didnt feel like paying more shipping in case I needed them.
The stock pads were brittle and broke when removing them gently.
One year on brass and all good.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Nice mine were torn off and turned inside so now I keep in stock. I just had my nephews apart and his was starting to tear and collapse as well. Good catch cannondale27.Great catch! I never saw anyone mention that and I forgot too. The cushion shown in bottom gear.View attachment 174458
Turboflash
- Mar 18, 2019
- Southern MN
Good to check. I've seen a few with rubber deteriorated, missing little pieces, etc.
Oh no....more parts to order in for spares....
acpantera
- Sep 25, 2004
- W.N.Y.
- 22 TCAT+ATAC+EPS
At the end of last season I put a hd top gear in and the brass fork pads, nothing wrong with the stuff I took out at 4,000 miles....except the gear bushing wasn't drilled to match the oil hole in the gear...still wasn't worn much.
- 13K
