did you buy or make the solid shaft?
I bought the Swedish steel shaft. Will look for a link.did you end up making a steel shaft taped on both ends or go bigger with 2 bolt's and tap the stock RR shaft?
4strokes
- Mar 13, 2018
- charlemont ma
- 18 winder xtx 09 nytro xtx 06 apex gt
so, that is a cat part? wonder what the need for the taper is.
Not a Cat part. It’s just tapered for wieght savings. It’s very well made but should be coated for rust.so, that is a cat part? wonder what the need for the taper is.
4strokes
- Mar 13, 2018
- charlemont ma
so the dealer in the link sells them? I didn't see it on their site. I shortened an old Polaris one in a pinch to fix a 12 snopro. If I recall, I was able to use Polaris shock bushings and made spacers. the rails had egged, I filled them in and plated the inside and redrilled. I can plainly see how stupid the long bolt idea is. I need to do my winder this summer before it fails, along with the upper arm shaft and 4 wheel axle with bigger bearings. Unless that shaft you showed has a stupid price, looks the way to go for me.
Right. Dealer in link sells them. They are made from some Swedish guys. I believe I paid $70.so the dealer in the link sells them? I didn't see it on their site. I shortened an old Polaris one in a pinch to fix a 12 snopro. If I recall, I was able to use Polaris shock bushings and made spacers. the rails had egged, I filled them in and plated the inside and redrilled. I can plainly see how stupid the long bolt idea is. I need to do my winder this summer before it fails, along with the upper arm shaft and 4 wheel axle with bigger bearings. Unless that shaft you showed has a stupid price, looks the way to go for me.
snow_rider
- Apr 2, 2009
- Tawas City MI
- 2018 Sidewinder LTX-LE 50th
Hello,
For anyone who already has the steel lower RR shock shaft, do you think it's possible to drill then tap the ends to the next appropriate size bolt? Or, would this make it too thin on the ends? (This in order to solve the stock long bolt from loosening)
Steve
Steve
I believe that would work. Use fine thread shoulder bolts and make the shoulder close fit to shaft and rail hole and that would really be a nice setup. Actually thats the way most Japan Yamaha skids shaft are done.Hello,
Steve
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
I would just get a tempered steel shaft and drill and tap each end with high grade bolts.
snow_rider
- Apr 2, 2009
- Tawas City MI
Ok, thanks cannondale, that's the route I think I'll take, a bit easier then making a new shaft, especially if it'll be strong enough and resolve the loosening!
Steve
Steve
4strokes
- Mar 13, 2018
- charlemont ma
If you go that route, it will still be hollow without the added strength if the long bolt. As I stated earlier, its pretty easy to get your hands on a solid shaft from an older sled. plus you wouldn't have to enlarge the rail holes, besides, there may not be room for a larger bolt in the rail channel.
snow_rider
- Apr 2, 2009
- Tawas City MI
Good point, I think I have an old solid shaft from a Pro Action skid, I may see if I can make that work too.
hman4
- Sep 22, 2014
- 2010 Apex, 2002srx, 2000 srx
Can you replace the front crossarm with the suspension still in the sled or is it easier to just pull it out?
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
You can change it with the suspension still in, but it’s easy to take the skid out. If I broke the front crossbar on my sled, I would be taking the skid out for inspection.
hman4
- Sep 22, 2014
0 miles on my sled yet but was thinking to replace it before I haul it off to storage. I was thinking I could just take out the 2 bolts and pull it out but I assume there is some tension on it from the forward shock and would probably be hard to line up when bolting it back in if I didn’t remove the rear bolts.
