Ron W
Anyone know how to remove the collars to get at the bushings in the spindles?
turbogts22
- Jan 16, 2021
- Spooner, Wisconsin
- Two 2010 Phazer GT's
On one of mine I had to heat them up with a mapp gas torch to loosen the rust bond. They're suppose to slide right off but rust is mother natures Loctite.
Ron W
Thanks. I'll try that. They move between the washers but seem like it's one pieceOn one of mine I had to heat them up with a mapp gas torch to loosen the rust bond. They're suppose to slide right off but rust is mother natures Loctite.
karl
- Dec 9, 2007
- Whitehorse, Yukon Territory
- 2015 Phazer XTX
mine were the same, I also heated and smithed a bit with a hammer and block to expand them. still had to drive the ski axle out with a drift and hammer.On one of mine I had to heat them up with a mapp gas torch to loosen the rust bond. They're suppose to slide right off but rust is mother natures Loctite.
- 47K
- 115K
