stingray719
Wow that's cheap...
must be a mistake!
I don't think so, the price for the chain is 46 bucks on that page and that is what I paid when I bought mine. Cat parts not parts from Japan..
Dirtbikekid1998
- Mar 3, 2013
- Maine
- 2014 Yamaha Viper LTX SE Hurricane 190hp Turbo.
Mr. sled how has the new bearing you found been holding up?Here are the bearing that went into my chain case.
This is the upper Wobble Bearing replacement:
Here is the lower bearing replacement:
Awesome... running the hell out of it with the Turbo and have zero issues so far... thats almost 3000 miles after the fix.
Dirtbikekid1998
- Mar 3, 2013
- Maine
Awesome!! Good to hear they are holding up, I will be replacing myn with the ones you found.Awesome... running the hell out of it with the Turbo and have zero issues so far... thats almost 3000 miles after the fix.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
It would be nice to know if yamaha has done anything about the upper bearing in 2016.
What is the proper chain tension setting ?
Dirtbikekid1998
- Mar 3, 2013
- Maine
I don't know on the 2016s but it is 1-1/2 turns out on 14s and 15sIt would be nice to know if yamaha has done anything about the upper bearing in 2016.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Ski-Doo used a plastic bearing cage on the 2003 800's Buddys engine went every 1500 miles till he got steel cage bearings put in it at 3,000 miles, then it stayed together!It a PITA!
I've had to change out my chain case twice now (due to me hitting rocks) both time I've had to buy them through Cat because they were either unavailable or on back order through Yamaha. To change out the top bearing you need to remove the retaining clip that holds in the bearing and then press it out from the back side. To do this you need to remove the chain case which involves removing the Jack shaft and the drive shaft.
Now with that being said each time I changed out the Chain case I ended up changing out the Cat bearing and putting the original bearing back in due to the Cat bearing having a cheep looking plastic cage and the Yamaha bearing having a metal cage
This is the Cat bearing
Dirtbikekid1998
- Mar 3, 2013
- Maine
Mr sled i found the ntn part number for the fag bearing you used. What bearing do you think would work better? the ntn or fag. i'm just asking because the ntn bearings are usually the best bearings you can get.
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
SKF,INA,FAG,good old Timken, are all better than NTN. At least for me. YMMV.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Ok, so did we determine that the failures are caused from improper chain tension? Or cheap bearings?I don't know on the 2016s but it is 1-1/2 turns out on 14s and 15s
My new sled comes to the dealer in the fall, then they have to install the mpi turbo, im also getting them to put a pre studded ice attack track and change the gearing.
Is there a better bearing that i should change out right away , or wait the original out?
Thanks for the input guys.
Would be nice to see them come with a regular ballbearing but Yamaha must have determined that we still need the wobble bearing even with the TCL deleted. Mine has made 6000mi so I guess its up to you. Really hasnt been that many failures.
Hey Mr. Sled. Where did your order them from?
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Alot of the plastic bearings with plastic cages are refered to as permalube bearings.
The idea behind it is they impregnate the plastic cage with a lubricant/grease and you never have to worry about lubricating it. Kinda like an oil impregnated bronze bushing.
From what i have seen these plastic caged bearings normally have a lower load rating then steel cage bearings and dont have the same durability as steel caged bearings.
For myself personally, i would never use plastic cage bearings where durability might be an issue.
I prefer to use the plastic cage bearings in light duty applications.
I had mine done at my dealer and they did not want me to have any more issues. They brought in a bearing guy and this was the best bearing on the market for that application.
Dirtbikekid1998
- Mar 3, 2013
- Maine
In the video a couple people have posted to show how to replace the bearings on a 1100 turbo osp installed a heavy duty jackshaft with there new bearings and it didn't look like a wobble bearing. Is that the same wobble bearing? It looked different because it was sealed on both sides. If it is a regular bearing it should fit in our case.Would be nice to see them come with a regular ballbearing but Yamaha must have determined that we still need the wobble bearing even with the TCL deleted. Mine has made 6000mi so I guess its up to you. Really hasnt been that many failures.
