Buzzing on track after track change
Hannibal802
Age
30
Vermont
Nytro
I just did a track change and extension with a skid relocate on my 2008 Nytro. I'm aligning the track, and I think its pretty close but I'm getting this awful buzzing sound when the track is turning.
I've almost got the adjusters the same, my finger fits between the slide rails and the track nubs on both sides but might be just a hair off. I've then tightened the axle. This is the sound it makes. Is it too tight? Or not aligned? I've checked all the bearings and replaced the ones that needed to be changed.
https://streamable.com/up2gt6
Yep forgot to trim them after putting the new ones on the rail. I trimmed them best I could without removing the skid just by removing the rear axle. Not as bad, should be OK after a little bit of riding, just no reversing for a bit till they wear.
