What issues(if any) are there to using the cat skid without a tipped tunnel(like the Cat tunnel). Do you have to mount the suspension any lower to avoid the rear smacking the back of your tunnel? Mines going in a Viper, haven't seen any with the cat skid yet.
It could very well be necessary to lower it in the tunnel. You would be best off to measure everything carefully before drilling the rear mount holes. Remove all the springs, mount the front (with the track ON), put the rear into a compressed position, and lift it into position to mark the maximum mounting height given the amount of clearance you desire.
