What sled does she have? I have seen the 129's have alot stiffer valving than the 137's. Also as posted there are some qs3's that are plain old defective. I would be happy to help you.I’m wondering what spring I may need for the girlfriends rtx se with the qs3s. I tried it and felt it was very stiff on the softest settings for the qs3s. Are these shocks just valved stiff? She even said it almost bucked her off over a bump. Slide springs are also on the softest setting. Will a center skid spring help or is it these qs3s? Thought these qs3s would be a lot softer on the softest setting. Sled is basically new and not even through breakin period yet, so I’m hoping the shocks will loosen up a bit.
My shocks on my ltx dx are amazing! It rides very plush, but also wondering if a spring would make it even better.
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
She rides a 16’ RTX SE with the qs3s.
Get them broke in and see about getting revalved if still too stiff for her.She rides a 16’ RTX SE with the qs3s.
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
Ok thanks cannondale. I figured they just need more use. I thought forsure those qs3s would be a better ride than my ltx dx, but I guess I thought wrong. I can barely push down on the rear when it’s on setting 3...it’s hard as a rock!
Setting 3 is XC setting! 1 or 2 is all most use unless very rough and in a hurry. Takes between 3-500mi to break in suspension. Wait till then. Your DX is like on 1 or even softer.Ok thanks cannondale. I figured they just need more use. I thought forsure those qs3s would be a better ride than my ltx dx, but I guess I thought wrong. I can barely push down on the rear when it’s on setting 3...it’s hard as a rock!
McLovin
- Jan 30, 2017
- Manitoba
- 1997 Mountain Max 700 144 1.5
Hey fellas. Was inspired to explore this due to the brutally heavy steering of my sled. 2016 Viper MTX 141se. We do a lot of riding, slow speed steering, on bush trapper trails. Sled is terribly heavy steering through these. Have been trying to sort through all of these threads and figure which Arctic Cat spring to go with and was thinking maybe a 180#. I want it to steer easily on these trails but still be able to have control at high speeds as well. Which 180# spring would fit?
https://www.snowest.com/forum/archive/index.php/t-416613.html
Or do you guys think one of the newer dual springs would be better? Thanks for thoughts/opinions/experiences!
PeeWee86
- Feb 28, 2017
- Minnesota
- '16 Viper MTX 141
McLovin- I would suggest you stick with the straight rate ZBroz spring. How much you weigh should have an influence on the spring rate that you select.
https://zbrozracing.com/center-shock-spring-kit-yamaha-viper-sidewinder
They have three different springs based on rider weight. 145lbs, 160lbs or 180lbs. I have the same sled that you have, I weigh 160 pounds and I’m using their 145 pound spring. I have it turned up to five turns from the point of contact on the adjustment collar. Prior to installing the spring I would have trouble getting stuck on asphalt at gas stations because there was so much weight on the front end. The installation of the spring has eliminated that problem. On the trails I still have heavy steering but that is most likely a result of my choice in skis. I have C&A bx skis and Shaper wear rods with 9 inches of carbide. No wash out in the corners at all. None. When I point it turns NOW. When I am Off trail it’s easy to lean back, crack the throttle and pull the skis up off the top of the snow.
ZBroz recommendation is to move to the 160 pound spring if the rider weight is over 200 pounds. I would suggest that might be closer to 175 pounds based on my experiences.
McLovin
- Jan 30, 2017
- Manitoba
Thanks PeeWee! I am 215 lbs with no gear, so would look at the 160 or 180 lb spring. Would get from Arctic Cat though, easier to get right away. So you think the 180 might be too much? And why are you recommending this over the dual weight springs?
Thanks a lot.
Thanks a lot.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
I have Bill's 160 pound spring in my Sidewinder. I weigh 200. I think the 160 would be what you want.
McLovin
- Jan 30, 2017
- Manitoba
Thanks lots guys. For my weight+gear I am right on the edge of the 180 lb spring. Plus PeeWee says those weights can be reduced a little bit. Tough call. Anybody tried the 180? I trust the recommendations though, and will prob do the 160...thanks number1kyster!
So nobody thinks a dual weight spring would be a better option?
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
McLovin
- Jan 30, 2017
- Manitoba
Trying to figure out which straight rate spring is which. Is 2704-229 a dual 160#/260#? The other 160# on this chart is discontinued, according to my Arctic Cat dealer.
2704-229 is dual rate. This source was pointed out to me. I have not tested them. Here:https://www.snowest.com/forum/archive/index.php/t-416613.html
https://www.qa1.net/suspension/springs/1-875-id-coil-springs
Happy Now?The center shock spring size needed is an 1-7/8" I.D. x 8" long spring. Pick your spring rate.
You can get the springs a lot of different places in all kinds of rates for pretty cheap. It is a very common spring size.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
They are on eBay as well in various brands.
