BAKOWBOY
- Dec 27, 2012
- WHITE LAKE,MICHIGAN
- 2015 SR VIPER LTX-DX
I have a 2009 nytro xtx, doing some mods to it....going to stud track just down center....factory track is clipped every third hole, someone has recommended that I clip every hole if I am going to stud ???? Help me out here ,,,,,good idea or not needed just adds un needed weight to sled ?????? Thanks
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Are you going to open up the other windows and run extros? If no its not necessary, its not really necessary to clip when you run extros stock. Recommended though. If your running stock drivers just stud it and your good to go.
BAKOWBOY
- Dec 27, 2012
No, just going to stud track, spoke with Chris @ Schmidt this morn on something else and he had the same thought ....no need to clip....Thx
09nytro
My 09rtx I cut out all the windows and clipped all , and had better hyfax ware to .....
A.Granath
- Sep 5, 2013
- Sundsvall, Sweden
- Sweden
- Yamaha Viper MTX 162" MCX Turbo 190
- Sundsvall
I swaped to a full clipped track and my hyfax now last for +2 seasons.
Fully clipped is the way to go. No rubber burning smell on warm days and better hyfax wear, less resistance, and better top speeds. I have an 09 xtx and had both.
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
I have a Powerclaw 153 and will fully clip. I can smell rubber on cold hard pack days. I have clipped all my tracks and the hyfax lasts longer.
Beenba
The money and time u spend clipping, you could invest in some wheels putting them in the right spots.
I've added wheels to my nytro when I got it in 2011, and have put 5000km on the hyfax and they are still over half. Its the only way IMO.
edit: I should note i used all normal Yamaha wheels and not the aftermarket company ones.
Once the clips heat up and the hyfax sticks to them, your done. Wheels don't do that.
- 57K
