jpilk99
- Dec 11, 2021
- Bolton, MA
- 2006 Yamaha Apex GT
So, I am back at the 2ndary clutch/belt and it's still loose as a goose. Rear of sled completely off the ground. Spun track... belt sitting a good quarter inch below top of sheaves.Best way to test belt is take it off and just set it in the sheaves. If it sits where we think it should then yes you need to spin it to get it up top. If it sits in the same place then there is an adjustment needed.
It’s possible there are shims or washers between the sheaves preventing them from closing more or maybe the clutch is stuck like the primary was and won’t fully close.
Stock these secondary’s have a bit of float, or loose back and forth to self align. I think with your set up the knurled knob needs to take up the loose you are seeing and the clutch needs to be aligned perfectly with the primary. Otherwise the adjuster would serve no purpose except for belt removal.
There are no spacers between sheaves. When I had it on the bench they were like a couple of kisser fish, smacked right up against one another. I am spinning the knurled knob counter clockwise as I believe that the spring inside the helix will push that "setup" (adjuster, collar with the 3 allen headed bolts, rollers, etc.) which - and I may be wrong here - is bringing the inner sheave out away from the engine and closer to the outer sheave, thus tightening. But that isn't happening. I've actually got this black adjuster knob so loosened that the whole clutch is sliding back 'n forth about an 1/8" to 1/4" inch. That can't be right, to be that loose, right? So when I snug that adjust knob in, to take up this 1/4" slide ...then the spring can't push that "helix setup" further away from engine to tighten...
Last thing I'll say is when I took the mounting/securing bolt off, then removed the black knob, there was a very thin washer/spacer (guessing here, but, maybe 1/32" thick) and about an inch & 3/4" outside diameter sitting just along the inner surface of the black knob ...and then a much thicker washer, about 1/8" to 3/16" thick and 3/4" outside diameter that sat down inside toward the splined shaft.
I'm thinking it's one of two things:
1). That those "washers/spacers" are impacting my ability to tighten sheaves together, thus tightening belt. Or.
2). The secondary clutch overall is a sticky/gummy mess and the is not functioning properly to allow the spring to push that outer collar out and taking the inner sheave with it...
Sorry folks if I just am a moron here. I can't figure this "easy to use" clutch out. I'm thinking I might be a lot better off with a stock Yammagucci. Seeing a few on ebay for $188 and less, under a $100....
Thank you.
Jay
