jpilk99
- Dec 11, 2021
- Bolton, MA
- 2006 Yamaha Apex GT
Oh yea, I'm a pro at using that black knurled adjusting knob. Spins super smoothly!!!Also, you were able to spin the outer threaded portion of that adjuster?
jpilk99
- Dec 11, 2021
- Bolton, MA
Agreed. I recall when I owned my '02 Viper and "track deflection" that it said exactly what you say here, that I should be about half that height. But I"m getting hosed somewhere/somehow with spacers or that I need less or more... I'm just starting to "play around" as 72Grand says with spacers.In pic 2293 the belt is a bit high, it should be about half that amount.
Ok, I guess I'm just wondering if you back off the knurled knob, why isn't it letting the sheaves come closer together.
jpilk99
- Dec 11, 2021
- Bolton, MA
You and me both, brother. What's really got me slammed is: When I continue to back off (loosen) the adjuster knob, it actually pulls away from the clutch such that there's play in the clutch, side to side.... on the shaft. The whole clutch just moves (together) in and out.Ok, I guess I'm just wondering if you back off the knurled knob, why isn't it letting the sheaves come closer together.
Agree sounds like you just need to get the spacers figured out, but once it is right you should be able to use the knob to fine tune the belt height - that is the purpose of it.
jpilk99
- Dec 11, 2021
- Bolton, MA
Agreed. I believe I need to add another spacer, in addition to the one I already added... I'll keep playing with it. Thank you.Agree sounds like you just need to get the spacers figured out, but once it is right you should be able to use the knob to fine tune the belt height - that is the purpose of it.
My sidewinder doesn't have the inner bolts anymore, none of them do. They use a large washer on the head of the bolt with a spacer and either .5mm washers or 1mm to set the belt height. Therefore, anytime one of the inner machinery washers is remove or added the outside stack must be re-adjusted. Yours is like this also more or less, I think you will figure it out, just keep studying it.
www.cyclepartsnation.com
2020 Yamaha SIDEWINDER L TX GT (SW1NLGLR) Secondary Sheave
Shop online for OEM Secondary Sheave parts that fit your 2020 Yamaha SIDEWINDER L TX GT (SW1NLGLR), search all our OEM Parts or call at 269-385-1540
jpilk99
- Dec 11, 2021
- Bolton, MA
Thank youMy sidewinder doesn't have the inner bolts anymore, none of them do. They use a large washer on the head of the bolt with a spacer and either .5mm washers or 1mm to set the belt height. Therefore, anytime one of the inner machinery washers is remove or added the outside stack must be re-adjusted. Yours is like this also more or less, I think you will figure it out, just keep studying it.
Shop online for OEM Secondary Sheave parts that fit your 2020 Yamaha SIDEWINDER L TX GT (SW1NLGLR), search all our OEM Parts or call at 269-385-1540www.cyclepartsnation.com
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
OK, i see it now.
Put a washer or 2 the size of the shaft or slightly smaller. We want it to go inside the sheave hole so sheave slides over it & OUT all the way.
Make it so it moves about 1mm on shaft with the adjuster loose when you tighten bolt. We DO NOT want the Adjuster touching the Helix yet.
Belt will be about 1.5 mm above sheaves like your picture on the bench.
NOW tighten the adjuster until belt is just above the sheaves. Flush to 1mm above is fine.
Need to tighten adjuster just a bit then run sled to let it "find" itself. It takes a couple pulls & DO NOT hit brake. Let it stop on it's own.
The Adjuster should not touch the Helix until you start to tighten it.
Let it touch it first, run it then tighten half turn at time until you get it. Run it each time twice.
jpilk99
- Dec 11, 2021
- Bolton, MA
Thanks Steve. Feels like I'm getting close!!! Will do as you said and report back; tomorrow. Need to go get washers of the size we're talkin' bout.OK, i see it now.
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
They need to be smaller then the shaft just a bit so the Adjuster will go over them.
DO NOT feel stupid or embarrassed. You're learning & it's actually fun, gotta admit.
This is the BEST way to learn. Hands on, figuring things out. Soon we'll be changing your name to Jclutchman99
OCD guys have 'eyes like an eagle'
LOL
LOL
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
OR, you could just put the stock bolt & washers on.
jpilk99
- Dec 11, 2021
- Bolton, MA
Steve, just wanting to make sure here: Basically use the same size spacer that's already there? It's "the size of the shaft or slightly smaller" but also allows the bolt to go through it.OK, i see it now.
Is that what you mean?
jpilk99
- Dec 11, 2021
- Bolton, MA
I think you answered it with your additional comment of "or you could put the stock bolt & washer on ..."Steve, just wanting to make sure here: Basically use the same size spacer that's already there? It's "the size of the shaft or slightly smaller" but also allows the bolt to go through it.
- 18K
