yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Thanks ALSIM67.8 g
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
So I did some testing today!! Weather was warm +3 degrees Celsius(warm) and my testing was done on approx. 1000 feet start, slow down and stop to turn around included on a hard packed road!
I started by replacing the rivets in the tip with the 4.5 gram weights Yamaha part #90261-06033-00. Then went for a test run and was whacking the limiter
So I decided to add the 3.1 gram yamaha part #90261-06019-00 to the center hole and took a test run and max rpm was 8890! seems spot on! I didn't have the room to do all long wot run but
I'm going for a ride Monday morning to do the real world testing hopefully it's right on the money!
Another thing with playing with the rivets I found that compressing them in a vise then hitting the jaw with a hammer then retightening worked well for install
All this testing was done in warm weather on Monday we are going back to -8 degrees Celcius hopefully in the colder weather I'm not back on the limiter
The sled is also not as jumpy of the start
incase you haven't read my previous posts I have a sandales pipe and airbox mod
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
tomorrow will be -10 and will be doing a big run so hopefully it's clutch perfect I'll report when I get backSo I did some testing today!! Weather was warm +3 degrees Celsius(warm) and my testing was done on approx. 1000 feet start, slow down and stop to turn around included on a hard packed road!
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Just got back from a ride! The trails and lake are hard from being +3 degrees Celsius to -10*C
On the lake wot for the length I hit 166km/h with a max rpm of 9273 I did not feel my self hit the rev limiter so it may have been on take off
Next I tried it out on a hard flat groomed trail and out of 3 trys I was hitting 9158 to 9191 rpm
Now the trail and lake were hard as rock I'm just wondering if I should get the rpms down a touch or leave it at is? I never felt the sled hit the limiter once! Thinking in a little softer conditions it may drop a bit!
Thought of maybe trying a gates belt(some claim it drops the rpm by 200)
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
If you didn't hit the limiter then leave it. As the snow gets softer it will pull the rpms down from there. Jmo
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I didn't feel the limiter but my rpm's are showing above the max 9250 on the lake run? I am out again tomorrow and there will be warmer temps so soften the snow!If you didn't hit the limiter then leave it. As the snow gets softer it will pull the rpms down from there. Jmo
I'll try again and give more feed back! My buddy with a totally stock 16 viper mentioned that he was hitting his limiter to too so it must be the hard conditions
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
I was just reading some of this again. Must be bored. Has anyone ever found an aftermarket helix with a deeper pocket and/or another secondary spring that is not as thick, but is close to the same force?
I had my sled set up pretty well last winter, but I read the posts about the shimming out the helix possibly causing issues. I agree with Cannondale the edge of my ramp was up on the buttons.
Anyway, I took out my washers and definitely lost some top end and want to get it back.
Studroes144
You can get your helix machined so that the secondary will shift more and so that eliminate the coil binding of the stock spring. I gained a few mph top end just by doing that on my sled.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
just curious how much did you machine out of the pocket?You can get your helix machined so that the secondary will shift more and so that eliminate the coil binding of the stock spring. I gained a few mph top end just by doing that on my sled.
Studroes144
I do remember that I had .080" taken out of the spring pocket, but I also had the actual neck on the helix machined too, if u take the spring out of the secondary and fasten the helix back on and open the secondary as if it's in full shift out you'll see that the neck of the stock helix limits the amount of travel. I'll double check later on how much got taken off there. You can't go much otherwise the secondary will open too much and the belt will hit the center hub which definitely wouldn't be good. I had a dalton helix which I just used as a guideline and had the stock helix machined to the same specs as the dalton one since they come already setup with a deeper spring pocket and a shorter neck.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Maybe I will just buy another helix from dalton. Anyone know of a good place to get one?
shagman
Vendor
- Feb 18, 2014
Order right from dalton. That's what I do.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Ok, thanks Shagman
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
I purchased my 46/40 helix with a 0.080" cut out of the spring pocket for $69.95 plus shipping and tax from a vendor here in MN.
I am not sure if I am allowed to post the vendor name because they are not a paid advertiser on this site. What is the policy on posting information on products from vendors that are not paid advertisers on this site?
fasteddie15x
- Jan 20, 2014
you could also order a secondary spring from thunder products $35 plus shipping, they are a vendor on here. They say this spring will not coil bind, so no machining of the helix is necessary. I installed this spring in my sled on my last trip of the season last winter and thought it worked great!
