Reaper
- Nov 10, 2005
- Starbuck, Manitoba
- 2014 SR Viper XTX. COTC, Hygear 141 pro link.
I tried the soft start spring this past weekend and its buttery smooth and the engagement is great. However, noticeable reduction in hard hitting acceleration. The sled just felt soft thorough the powerband. But for the first time I hit 100mph on the speed and could never breay 90mph with the G-W-G!
stingray719
Yep, add the thunder product shims if you want that hard hitting mid range back. start with 4mm increase to 6mm for mid range. Quick and easy to do just pull clutch cover. less shims more top, more shims more mid
Reaper
- Nov 10, 2005
OK, already running 2x Yamaha shims. What is the difference with Thunder products shims?
stingray719
No real difference just usually easier to get. 2mm in my testing was not enough, try 4mm.
Reaper
- Nov 10, 2005
I'm in Canada remember, nothing easy to get here My local dealer has them, will through in 2 more and see how it works.
Reaper
- Nov 10, 2005
These ones?
Clutch Spring Glide Washer Kit
stingray719
These ones?
NOS-PRO post the thunder products link to shims please?
Reaper
- Nov 10, 2005
Hey NOS, I got my 100mph with the soft start spring and 2 shims but suspect when I put in 2 more shims I'm a gonna loose it
1049triple
- Jan 19, 2009
- Pohenegamook, Qc
- 2025 SRX (on order)
2018 High Country 9000
2001 SRX 700
Test it. It won't be long and you will be glad you found by yourself what work's best for you.
stingray719
Maybe not, extensive testing with COTC showed 4mm was the sweet spot for top end.
Reaper
- Nov 10, 2005
With the S-S-S ? We shall see this weekend
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I started hitting the rev limiter hard toady all day every time I hammer the throttle and wide open runs I think it's time to put the 4,5g weights! On wide open run it would go to 9250 wack the limiter and rpm's would drop to 8800 the climb back to 9250 over and over! If the 4,5g weights aren't enough May try a gates belt from what I read this belt will lower rpm a little compared to 8dn!
- Apr 14, 2003
- Hessel, Michigan
Just have to try bud!
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Well added 4,5 gram rivet and I still hitting the limiter hard every time I hammer the throttle and when running wide open on the lakes!! I have the air box mod and sandale pipe! Weird cause I wasn't hitting it throughout the season It just started this week!!
Any suggestions?? Primary I have the gwg spring with 4mm shims 8FP weights with 4.5grams in tip
secondary 45 39 helix with stock spring
The sled won't go over 150km/h because of the drop of rpm when wacking the limiter speed drop the goes back up then drops over and over
8DN belt
8DN belt
stingray719
8DN belt
That's a good problem to have! Add some weight, each gram should drop the rpm about 200 rpm. Also if you are set 6-1 on the secondary try 3-3, will drop rpm a bit and give a little less mid range and more top.
