blackhawk
Turk
Tech Advisor
Not even remotely close!
blackhawk
What will work on grass for 660ft?
Turk
Tech Advisor
Grass is usually 500' ; never ever heard of grass being 660. Gear down & I had great luck with heelclicker weights on that sled with
running the stock secondary & tighten up the secondary spring 10 or 20 degrees.
blackhawk
Thanks for the info.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Are you running in a trail stock application? Stock track? How many studs? We can help you with a setup as we have had an Apex and Attak with stock track and trail studs setup on the grass for the last two years. Give us a call if you would like.
