Mototown
- Sep 11, 2018
- Apex 40 th
On the weekend I noticed on my temperature on the intake was about 10-15 warmer with the aftermarket intake than a stock intake temperature reading while riding ( switch to another sled ). Anyone else notice this ?
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
Yup. It pulls under hood air but more of it with less restriction.On the weekend I noticed on my temperature on the intake was about 10-15 warmer with the aftermarket intake than a stock intake temperature reading while riding ( switch to another sled ). Anyone else notice this ?
fourload
WAI. I have been through this with my pickup. They offer less restriction but let warm air in. They sound good but offer little in the way of major hp increases for a trail rider.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
X2 stock setup cooler.
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Although most people don't like them, this is why I went external CAI. I wish I could put some miles on to get some data.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Yes, I noticed it last season. It should be called WAI or warm air intake, because its not cold or even cool!
https://ty4stroke.com/threads/cooling-down-the-intake-temps-when-warm-out-hot.151838/
I notice 100* air using a thermometer in front of the supposed CAI filter. So 100*F air being inhaled and this is with the filter shoved right up to the factory intake up front. I shoved the filter outside the hood and it got WAY leaner than I wanted to see.
I went back to the stock intake on my last ride out. Intake temps cooler along with cooler belt and clutches. Everyone thinks the stock box limits air to the clutches, but it actually gets more as its not being consumed by the engine and the cool air goes to the clutches easier.
The problem is the stock box is a bit more restrictive and the CAI or I'll call it WAI will pull more clutch weight it seems IF YOU CAN KEEP TEMPS BELOW 90-100F!
Doug Heald
- Jan 2, 2019
- Maine
- 2017 LTX SE Yamaha Sidewinder
Hi guys, is there a way to block off warm air from eng, or pull out vent screen, my CAI has a pre filter on it,
lilrez
- Feb 7, 2016
- Near Ottawa
So...sounds like the cai may not be the best idea for a strictly trail setup .?
Im not into radar run hp anymore .
chaleurphantom
- Oct 5, 2009
- Northern New Brunswick, Canada
- 2018 SIDEWINDER LTX-LE 50th Anniversary
2016 VIPER XTX LE - WHITE,
2009 VENTURE GT,
1995 POLARIS INDY 500,
1984 SKI-DOO CITATION 3500
I have a CAI and I watched the Air Intake Temperature today. I was between 45f to 60f. I don't recall what it was stock? Anyone recall?
bleedyamaha
- Sep 28, 2013
- Northern Iowa
My last trip with stock box was anywhere from 45/60. My cooler was plugged with snow and ice if that makes a difference
KnappAttack
- Feb 19, 2004
- Welch MN
I was between 28-35F or so last time out up north with the stock box. Right around 10*F over air temp crusing and riding around. WFO pull and would heat up very fast though, but cooled down much better with the stock box over the CAI.
I have the stock box back on it again for now. It just plain runs cooler along with the belt and clutches.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Knapp do you have the google bag installed above your handle bars? There is so much heat in my bag. I am going to run it with the factory screen to see if that helps let the heat escape quicker.I was between 28-35F or so last time out up north with the stock box. Right around 10*F over air temp crusing and riding around. WFO pull and would heat up very fast though, but cooled down much better with the stock box over the CAI.
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
I have the conical shaped CAI where the air is forced into front of it. Works great and was good for 5hp on dyno. Intake temps same as stock for me. Wont mention name but initials are A.K. whom I bought it from!
lilrez
- Feb 7, 2016
- Near Ottawa
Alex Keaton ? ,
lilrez
- Feb 7, 2016
- Near Ottawa
Do you not notice improved throttle response with the k&n setup ?
Ill have to take a look again..... why would clutches tun cooler with plastic airbox. ?
