See pictures from below (access panel removed), brand new 2025 SRX, 0 miles, no leak from hose clamps at the back or front of the exchanger. Puzzling! I'll have to go to the dealer (next Monday), seems that the leak comes from the exchanger itself.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Could be leaking on hose under gas tank and exhaust manifold. Look up past front of track over drive axle with a mirror.
Turboflash
- Mar 18, 2019
- Southern MN
Could factory/dealer have spilled coolant while filling sled?
I did check and saw nothing.Could be leaking on hose under gas tank and exhaust manifold. Look up past front of track over drive axle with a mirror.
How would it be there and nowhere else?Could factory/dealer have spilled coolant while filling sled?
Turboflash
- Mar 18, 2019
- Southern MN
Clamp tight? Hose ok?How would it be there and nowhere else?
Any chance it's leaking down from Turbo connections or turbo cooling tank connections?
Just brain-storming here. The welds on heat exchangers are supposedly tested to be air tight.
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
Common. Go over every single clamp of any kind you can find on the sled. Betting you'll tighten them at least a full turn.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Turboflash
- Mar 18, 2019
- Southern MN
Crank shaft run out is tested also correct??
Pstn head
Check hose clamps going in and out of oil cooler.
I did my best to check everything, I also used an inspection camera. No leaks from any hose clamp. Starting engine until warmed, collant comes again at the same place. I see no other possibilities than leak coming from the bottom of the exchanger. Sled is now at dealer, they will check that tomorrow.
I wonder if they will have to remove chaincase to get access to rivets.
Finally, dealer concluded that the heat exchanger is leaking and ordered a new one.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Better at the dealer, then Trailside. Glad It got figured out.Finally, dealer concluded that the heat exchanger is leaking and ordered a new one.
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
Brand new sleds should never have this type of problem but unfortunately it not the reality we live in… That should have never made it past the dealer that set that sled up or the factory when they did their final checks… Someone was paid to do I job right and failed and now this guy has to spend his time and money and loss of use to fix that mistake… Maybe that why a certain of manufacturer is not doing well and is in trouble…
- 25K
