Psycho Dave
- Jan 8, 2013
- Norderåsen
- Sweden
- 2021 Arctic Cat Riot X
1986 Aktiv Karibo
I managed to destroy my engine ECU due to stupidity during fault tracing of my fuel pump relay. So I need a new, but what are the differences?
2007: 8GC-8591A-00-00 (with cold start problems)
2008: 8GC-8591A-10-00 (with cold start fix, I have this one)
2009-2010: 8GC-8591A-20-00
2011-2013: 8GN-8591A-00-00
2014-2016: 8GN-8591A-10-00
I have a Venture Multipurpose but it has the same ECU as Phaser RTX, thought I might get some more answers here. Does the newer 8GN work on a 2008 that had 8GC originally? Any improvements worth the extra cost?
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Pretty sure the 2011+ ECU have the "improved" low oil pressure shut down system, I'm not sure if those sleds use different sensors or not, 2010 and older should interchange though.
Psycho Dave
- Jan 8, 2013
- Norderåsen
- Sweden
1986 Aktiv Karibo
OK, they have the same oil pressure sensor but I will play it safe.
Psycho Dave
- Jan 8, 2013
- Norderåsen
- Sweden
1986 Aktiv Karibo
Just as a note, the newer ones it uses one extra oil pressure sensor.
- 236K
