DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I did allows more air to get in or out from the cab through the frogskinsJust curious are you guys removing that panel under the instrument when using the CAI? Looks like more crap that could be removed per Dans thread as well.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Once I change from stock to CAI setup with flash, I will remove that for sure..more airflow and less weight, as mentioned before here. Not my idea but a great one! Id like to remove more weight anywhere I can! haha
Dan
Dan
rnusr01
- Nov 6, 2016
- CT
- 2021 MXZ-XRS 850
Me too, I need to layoff the beef.....Once I change from stock to CAI setup with flash, I will remove that for sure..more airflow and less weight, as mentioned before here. Not my idea but a great one! Id like to remove more weight anywhere I can! haha
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
LOL....I need to add some weight to me, and less on my sled...hahaMe too, I need to layoff the beef.....
I can eat like no other, and still cant gain a darn LB....haha
rnusr01
- Nov 6, 2016
- CT
- 2021 MXZ-XRS 850
Thats just not right......good for you
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
BRP Renegade mxz 800
We must be brothers haha...
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Has anybody found a k&n filter to replace the foam filter inside the air box?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Dont think they make one, but that is a valid question, as stock foam is poor at flow.Has anybody found a k&n filter to replace the foam filter inside the air box?
Other issue with that is, the channels above the big airbox on clutch guard, are rather restrictive at several points. So even if you added a hi flow filter inside stock box, I dont think it would be a worthy upgrade. Not too mention you still have the massive box there blocking all the airflow from front screen down left side....CAI is something that does many good things all at once.
Dan
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Here is mine
Air filter K&N rx-3800. Pre filter rx-3820-pk.
rnusr01
- Nov 6, 2016
- CT
- 2021 MXZ-XRS 850
Here is mine
View attachment 133280 View attachment 133281View attachment 133282
Byam, nice job heres mine came out nice. Really like the fitting made for teflon hoses for the other vacuum line
rnusr01
- Nov 6, 2016
- CT
- 2021 MXZ-XRS 850
Byam, nice job heres mine came out nice. Really like the fitting made for teflon hoses for the other vacuum lineView attachment 133423 View attachment 133424
Thanks to Rockerdan for assisting to locate this stuff
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Maybe you can remind me where you found that slick nipple for rearward breather hose.....it looks great brother!Thanks to Rockerdan for assisting to locate this stuff
ty
Dan
rnusr01
- Nov 6, 2016
- CT
- 2021 MXZ-XRS 850
ty
Dan
https://www.viperperformance.co.uk/
It was quick shipping as well and quality is fantastic
Never Satisfied
- Oct 10, 2017
- Madison
This is slick by Silicone Intakes if you want to hook these up.
http://www.siliconeintakes.com/holset-turbocharger/-p-500.html
http://www.siliconeintakes.com/turbo-piping/
aquaticlaker
- Feb 21, 2009
- Green Lake WI
- SIDEWINDER L‑TX LE 50TH
- Green Lake Wi
