Jd2859
- Dec 2, 2019
- La Crosse,Wisconsin
- 2020 sidewinder LTX GT
Well got the sled somewhat set up for grass and wanted to test clutching and anti lag looked every thing over after I was done and I guess I had a loose stud what you guys think throw a new stud in or get a new track
TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
How many miles do you ride? That comes apart up in the UP you got a problem.
Jd2859
- Dec 2, 2019
Lucky to put on 1200 a season I’m more concerned about doing 1500-2000ft pulls on the lake
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
If it were mine I’d put in a stud and go. That stud just loosened and went away, it did not pull thru. Track looks fine to me.
RobX-1
- Coldwater, OH
IMO I'm not so sure the track isn't damaged around the stud hole as it sure appears there are two rips (circled in red) leading to the stud hole and I would fear putting in another stud will just rip out but this time might cause more damage than just going away. As for the track itself, I wouldn't have a problem running it but just wouldn't put in another stud and leave the hole empty.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
If this is the only issue with the track , I would put in a stud with the largest stud head and backer , and the shortest stud , as short as you can find, so that it has the least amount of pressure from the ground.
Also can put some rubber glue to help it stop from ripping further .
Jd2859
- Dec 2, 2019
That’s kinda what I was thinking.. I was just gonna order another short trigger stud and pack some type of glue on both sidesIf this is the only issue with the track , I would put in a stud with the largest stud head and backer , and the shortest stud , as short as you can find, so that it has the least amount of pressure from the ground.
What's the miles on this track?
Good eye. What is going on to left of hole? Is that a lug that’s torn off? If so ditch that track.IMO I'm not so sure the track isn't damaged around the stud hole as it sure appears there are two rips (circled in red) leading to the stud hole and I would fear putting in another stud will just rip out but this time might cause more damage than just going away. As for the track itself, I wouldn't have a problem running it but just wouldn't put in another stud and leave the hole empty.
RobX-1
- Coldwater, OH
I believe that is just the top of the lug with some excess rubber flashing (or whatever you would call the leftover rubber from the molding process).
kinger
Use vulcanizing cement for the glue and slather it on the backer and under the head, then use a short stud and run it. That doesn't look bad to me at all.
Jd2859
- Dec 2, 2019
1800What's the miles on this track?
Jd2859
- Dec 2, 2019
Yea I was planning on getting one that most likely won’t even stick above the lugUse vulcanizing cement for the glue and slather it on the backer and under the head, then use a short stud and run it. That doesn't look bad to me at all.
Honestly if you're not going to put a stud in that's functional why bother? If you're not going to benefit from traction leave it open. Not like a stud is going to hold it together. I had a couple pro lites rip some windows open on my ripp II and contacted Camso about it and they said not to worry about it. Said run it no problem. Mine had 4600 miles on it.
Yea if that’s flashing on that bar next to it that track is like new yet! Normally that flashing is wore off right away. I would just leave the hole empty,tighten the rest and ride on.
