Alatalo
- Jan 11, 2005
FMI, are you talking about the "cheater" hi-flo header (the one that runs into the stock silencer) or the "full" exhaust kit header...?
In my opinion, correct center-to-center distance on all of the header pipes is critical. The flex tubes can handle vibrations, heat expansion and other variances in the longitudinal direction, but once you force them sideways (because of incorrect center-to-center distance), you are risking them to crack within soon...
Phyxius74
I'm talking about the "cheater". It is the sideways center-to-center that is a little bit of and I needed to force into place. And my worries are exactly the same as yours, that the built in tension will eventually cause som cracks.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Phyxius74 said:I'm talking about the "cheater". It is the sideways center-to-center that is a little bit of and I needed to force into place. And my worries are exactly the same as yours, that the built in tension will eventually cause som cracks.
Then send it back for a new one?
Phyxius74
SledFreak said:Phyxius74 said:I'm talking about the "cheater". It is the sideways center-to-center that is a little bit of and I needed to force into place. And my worries are exactly the same as yours, that the built in tension will eventually cause som cracks.
I will talk to Ulmer about it and hear what he thinks.
- 86K
- 158K
