extroverts
ApexSS
Lewiston Maine
Just wondering if anyone is running skidoo or Avid extroverts?
I have an 07 RTX w/ a ripsaw track that has all windows cut out w/ only everyother clipped. Can I run the extro's like this? My dealership says I need a fully clipped track but he won't even clip then rest of the track which I don't get....am I missing something?
Whats the difference if they clip it now or last year (only put 1000 miles on the track last season)?
Thanks for any and all advice,
Sean
You can run external sprockets as long as all holes are punched. They do NOT all need to be clipped. You can clip the remaining if you want -- its better if you do, but ripjunk is a terrible track -- hardly worth putting any money into it. Doesn't matter when you put on the clips.
Not sure why you want to run external sprockets. If its ratcheting, you really should concentrate on the cause for the ratcheting rather than trying to cover it up. Ratcheting is caused by damaged arms, worn bushings, or something being out of adjustment.
Re: huh
ApexSS said:
From what I understand, all/most 07 RTX's ratchet and extro drivers fix the issue......
Yes as well as other apex's, and FXnytros are notorious for it!
I have some whal bros and I love the fact that I cant ratchet anymore.
