hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Updated 12/15/15- New items in Red
RX-1/Apex/Vector parts
set of ohlins clicker ski shocks for any year apex, vector, attak, rage….425
gytr clickers for any year apex, vector, attak, rage...350 for set
set of gytr clickers for any year apex, vector attak or rage…400. rebuilt. 0 miles.
fox float 1 for vectors and apex....300
New kimpex extroverts on used driveshaft….145
Apex seats. Great easy upgrade for rx-1 and 05-07 Vectors…..275
Rx-1/rs vector windshield bag…15
Team secondary clutch….200
set of apex/vector/RS Nytro fox floats with resi’s added….350
set of custom muffin works Billet one piece 136 apex rtx/rs nitro 136 rails…200
(2) blue skid plates
set of whal brothers extroverts on axle…175
Fox Mega Float mono Shock with pump….400
set of Fox float 2’s for apex, vector, rage, attak…..375
11-15 apex D&D Clutch kit. Magna force tunable Weights, Spring, and helix….225
LTX, Attak, Rage 136 rear heat exchanger/coler….250
2012 apex heavy duty drive shaft with extros machined to fit 06-09 Apex & 05-09 Vector…225
Set of ohlins piggy back resi ski shocks for any rx-1 or rx-warrior….350
(2) sets of RS Venture style mirrors for RX-1, Rage, and 05-07 Vector, and Warrior…50
Set of fox floats for RX-1 or rx warrior…325
03-05 RX-1/Warrior rumble pack muffler…..175
Clutch side bulkhead repair kit….125
Ohlins EC shock….300
Aluminum body rear skid shock…piggy back clicker for 05 Vector…250
13mm Sway bars…85
Ohlins EC shock with hygear revale and dual rate spring….400
GYTR clicker shocks with hygear hi/lo valving and dual rate springs…450
Heavier torsion springs for 05 vector…100
Yamaheater plug and play for apex….145
Custom bult heavy duty aluminum front bumper….75
Apex Radiator & Fan Kit for an RX-1, 05-07 vector. Includes wire harness and switch…$100
RX Warrior/ Rage Pro action rear shock with compression dampening & big boy spring….150
Misc
5” black spoked yamaha accessory idler wheels with replaceable bearings....15 each
(6) "yamaha" riser foam handle bar pads....8
(2) sets of low snow wheels and mounts. ..45 per set
M10 121” suspension with ohlins shocks….400…needs a little TLC
M10 121” suspension. Excellent shape….500
Misc front shock covers….10 a set
large 7” spoked Yamaha rear wheels, blue, yellow, red, and black available…18 each
5” blue spoked yamaha accessory idler wheels with replaceable bearings....15 each
Skis/skags
Simmons Gen 1 Black with black loops…200
Simmons Gen 1 Blue/grey with grey loops…200
Simmons Gen 1 Black with yellow loops…200
Simmons Gen 1 Red/black with red loops…200
C/A XT model Blue with Black loops. 7.25 wide. $275
C/A TRX model white with black loops $225
SLP SLT model. All black. $175
Yamaha Tuner Skis Black with 6” center runner, round bar outside…150
Yamaha MTX Skis….150
Used Snow Trackers Semi Aggressive….145
Used woody’s dooly runners…50 a set
Used Triple points….bit nicked up…40
Nytro Parts
set of blue foot holds....40
Fox float 1…350
black billet aluminum top handlebar clamp (says FX Nytro)….20
Brand new oil tank….150
RTX Remote Piggy back front skid shock…rebuilt..0 miles…325
RTX piggy back rear skid shock…275
Black skid plate…50
Red skid plate…50
Ohlins piggyback resi ski shocks…350
(1) 2011 XTX 144 skid….600
1600 Nmm Heavier rate torsion springs for xtx...125
1900 Nmm heavier rate torsion springs for xtx….125
Excell Full Exhaust. Headers, can & plastic….600
Power Comander V….250
Ulmer K&N Intake Kit….100
Fox Float X Piggyback shocks from an SE model…400
XTX torsion spring spacers….40
GYTR Yamaha Black Tunnel Reinforcments…new with rivets…never installed…225
Phazer parts
New extroverts on used shaft….145
Oem phazer radiator fan…75
R6 radiator fans with hardware to install…45
Red skid plate….50
Windshield mounting brackets…75
07 Fuel tanks…add 1.1 extra gallons of capacity to an 08-16 Phazer. Direct fit….$50
GYTR piggyback clicker shocks with only 600 miles….400
Fox Zero Rebuildable front skid shock…150
Fox Zero rebuildable rear skid shock…150
09 front skid arm upgrade kit for the 07 models…375
Tracks
121x15x1.25 ripsaw. Not fully clipped….325
144x15x1.25 rip saw clipped every third. All windows open. Like new take off…400
(1) 144x15x1.25 rip saw clipped every third. All windows open. Studded…400
(1) 136x15x1.25 rip saw studded…300
136x1.5 predator full clipped….350
(2) fully clipped 121x15x1.25 ripsaw tracks…excellent shape. Never studded. $375
(1) 14x1x121 phazer hacksaw track. Only 600 miles. Excellent shape. $325
1.5” x 121 Fully Clipped Camoplast Intense with studded. Excellent shape…475
13mm Sway bars…85
Misc
Skis/skags
Nytro Parts
Fox float 1…350
Black skid plate…50
Red skid plate…50
Phazer parts
Red skid plate….50
Tracks
rx1 fern
do you have a reverse handle mechanism section for yamaha rx1 .looking for the complete zinc coloured section that bolts to delta box with 3 bolts .if so how much shipped to manitoba canada .please and thanks
crusen32
- Nov 2, 2014
- Sandy creek ny
- 2013 Yamaha nytro k&n intake,jardine slip on under tunnel exhaust, pc3
Do u have any clutch kits for fx nytro
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
None right now. Lots of guys just run the soft start spring I sell.
philip
- Mar 20, 2015
- manitoba
- 2012 nytro xtx. Custom turbo 200hp and 153 2" track
Looking for a set of floats or adjustable shocks anything different then the standard coil overs for my nytro
Sent from my SM-G920W8 using Tapatalk
Ride1way
Interested in the ohlin piggy backs for rx warrior front.
Is the shock u have listed for the warrior proaction a ohlins or stock shock with big boy spring
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Rear shock was a stock shock with big boy spring. I just sold it this week. I do still have the ohlins front shocks.
W
WILDWILLY
Do you have any of the Nytro side deflectors for the windshield? Also can I get pictures of the ohlins shocks you have listed for a nitro? Thanks
AttakSnow2
- Aug 17, 2005
- Merrill, WI and White Pine, MI
- Yamaha Viper
Do you still have a ec ohlins mono shock available for an Apex?
Mileage Quest
In line for the tuner skis and gytr with dual rate
PM price shipped to 55443
trailhed1
Sent you a PM
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Here are a few new items
Tuner skis with 6" carbide on both runners...175
sr viper ltx or xtx large wrap around saddle bag....150
1.5 " x 121 ripsaw fully clipped with 96 studs only 100 miles on it...475
0em Phazer cover....85
Low snow wheel kit....50
2" rox pivot riser...45
Fx nytro items
Windshield bag....20
Med windshield with deflectors....70
Gytr front ski shocks...375
Gytr rear bumper...100
Ulmer clutch kit....weights, spring and helix.....$300
Black trail tank....200
Yellow skid plate....40
Fx nytro items
xrayjohn
- Sep 28, 2010
- Frankfort, IL
- 2006 Apex
- Frankfort, Illinois
Do you stii have the 13mm sway bars? Are they for a 2006 Apex?Updated 12/15/15- New items in Red
13mm Sway bars…85
Misc
Skis/skags
Nytro Parts
Fox float 1…350
Black skid plate…50
Red skid plate…50
Phazer parts
Red skid plate….50
Tracks
Mileage Quest
He's out on a snowmobile trip... Give him a couple days to replyDo you stii have the 13mm sway bars? Are they for a 2006 Apex?
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Interested in the nytro trail tank...
Would you know what generation the tank is..? First models or the newer design...?
Also interested in a few other nytro items you have for sale...
Thanks...
Thanks...
- 50K
