Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
How is the team clutching holding up on the thunder cats. Anyone know.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Not saying you have flat spots, but you really got to look at them in the right light. a lot of light. I had a couple small flats .. 50 milesI checked my low milage unit. Rollers show no signs of flat spots.
Thanks again........ Joe
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
my low mileage unit has zero...checked...the polished ramps might not be hurting me (yet)
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I better look at mine then lolhttp://www.ulmerracing.com/Secondar...&browse=-73647&shopBy=-26776&catalogId=-11683
We've been working on replacements for a while (since summer time).
I believe going out and running with 0 miles on it and going wide open instead of giving the rollers a little break in time, may cause some of the issue as well, but I can't confirm 100%.
Jafo1970
- Dec 2, 2016
- oshkosh, wi
- 17 sidewinder, doo 850
57 miles on mine and one had a flat spot. In go cat rollers. Apparently they didn't test with these rollers.
69redmach!
- Nov 27, 2016
- Loudon
- 2017 Sidewinder LTX SE
Mine are still round at 450 miles. Is this bad rollers or are they binding?
BTbt
- Apr 11, 2005
- Kettleby, Ontario
- 2017 Sidewinder LTX LE
another 100 kms yesterday, one small flat spot now
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
This is going to need to be addressed.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Are these the same diameter as the crap ones coming with the SW?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
it essentially becomes a button clutch...obviously the material is too soft..
fyi if one wants to experiment for less money...theres a regular (non torlon) version for $8.50 ish
BTbt
- Apr 11, 2005
- Kettleby, Ontario
Can rollers be changed without removing helix?
BTbt
- Apr 11, 2005
- Kettleby, Ontario
Do pins come out easy after screw is removed?
Jafo1970
- Dec 2, 2016
- oshkosh, wi
Remove screw, use big flat head screw driver to relieve tension off roller and use magnet to pull pin up and out. 2 minutesDo pins come out easy after screw is removed?
BTbt
- Apr 11, 2005
- Kettleby, Ontario
Easy to relieve pressure on rollers, just twist helix a touch, just wasn't sure how tight pins were.I had few Cat's with roller secondary clutches, Thundercat, Zrt 800 and a few Firecats, never any issues with clutches.Many other issues but they had secondary figured out.
justin1620
- Feb 3, 2014
- Rainy Lake, Ontario
- Sidewinder
- www.rustymyers.com
- 6K
