welterracer
kinger
Hey Allen if you get a sec check the front end on my sled and see how loose it is. Thanks
MotoPsycho
Alan,
Will the Apex kit fit a Holz front end?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Moto, never had any Holz items in my hands before. Can you give me any measurements? Just need the ID in the tubes where the bulkhead bolt goes through.
4bangpower
Allen,
Did Yamaha make any corrections to the OEM bushings for the 2010 model year? Or would you still advise to go with your bushing kit for the 2010 XTX?
- Apr 17, 2003
- Menno, SD
- Menno, SD
Still the same for all 2010 models.
kinger
Allen did you get a chance to check mine? I may need a kit when we pick it up
SIMMER
Hey Allen....in need of a bushing kit for a 2008 Apex LTX. Have any? PM me if you do and let me know how you want to arrange payment.
mach9
Me too... Allen.
Bushing kit for the 09 XTX Nytro required.
Tried to call and email... You must be busy.
Should I tear appart my front end this weekend??
Need to know if you have stock.
mach9
mach9
should you grease up the new bushings when replacing them? Mine arent oilite.
Also should I fill the arms with grease before replacing the bushings and putting the bolts back in?
thanks
thanks
- Apr 17, 2003
- Menno, SD
- Menno, SD
The oilite you can put a thin film of grease on when assembling, but I would not use a ton of grease.
Apex/RX/RS Bushing Kits: Out of stock for 10 days
FX Nytro 08 & 09: In Stock
Phazer: In Stock
Phazer: In Stock
sheetwright
Allen sent a PM. Looking to see if you carry bushings for the Timbersled barkbuster front end for the Apex, and the 42" wide Nytro kit? The are a 2006 Apex, and a 2008 Nytro? Thanks
- 7K
- 146K
- 11K
