Carla 123
- Feb 27, 2017
- Lester beach
- 2015 viper xtx boosted
17 zr9000 precision stage 3
After seeing my buddy on his cat having to remove his hood trailside in sub zero temps last week from a popped fuse that took out his dash and hand warmers I moved my Fuse box to the beltguard as per the viper frequently asked questions.anyways would someone know where to get a fan jumpers as I feel that it just makes it and would like to have a little more slack in the wiring.barn of parts doesn't carry these anymore as he says they are not needed.
BLH
- Mar 18, 2017
- Wisconsin
- 2016 SR Viper LTX-SE
2023 Sidewinder 137
I agree - I did the BOP thing but ended up drilling new holes in their mount to move the fuse box about 3/4" forward otherwise my fan wire was too short on my 2016.
Carla 123
- Feb 27, 2017
- Lester beach
Well Travis said it was not needed but I don't like the wire that tight .if I move the fuse box anymore forward the side cowling hits it.
BFS
- Jan 26, 2015
- 2016 LTX-LE
Red/White
Go on eBay, by a fan reverse harness, swap the pins in the harness and that will give you the extra length. I had the fan reverse harness installed until it turned out to be no help and just swapped the pins so it was normal.
Carla 123
- Feb 27, 2017
- Lester beach
Thanks for the tip but went on eBay and $40 to my door is a little much lol.wonder if I couldn't cut the wire and solder wires to make it longer and then heat shrink?Go on eBay, by a fan reverse harness, swap the pins in the harness and that will give you the extra length. I had the fan reverse harness installed until it turned out to be no help and just swapped the pins so it was normal.
Jim R
- Aug 30, 2015
- Rockford MI
- SR Viper / Procross
Make your own. They are Weatherpac connectors available at any GM or Auto parts store.Thanks for the tip but went on eBay and $40 to my door is a little much lol.wonder if I couldn't cut the wire and solder wires to make it longer and then heat shrink?
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
I also did mine as per the picture, my fan wires still reach. This is on a 16.5Is the Viper dif than the 7000?
I moved it and it has slack in the fan connector.
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
I am pretty sure I was a part of that fuse swap. Easier than I thought it would, but not as easy as doing mine that was relocated.
Carla 123
- Feb 27, 2017
- Lester beach
Lol you were.I am pretty sure I was a part of that fuse swap. Easier than I thought it would, but not as easy as doing mine that was relocated.
- 22K
