Fuse box relocated
Carla 123
Manitoba
Canada
2015 viper xtx boosted
17 zr9000 precision stage 3
After seeing my buddy on his cat having to remove his hood trailside in sub zero temps last week from a popped fuse that took out his dash and hand warmers I moved my Fuse box to the beltguard as per the viper frequently asked questions.anyways would someone know where to get a fan jumpers as I feel that it just makes it and would like to have a little more slack in the wiring.barn of parts doesn't carry these anymore as he says they are not needed.
I agree - I did the BOP thing but ended up drilling new holes in their mount to move the fuse box about 3/4" forward otherwise my fan wire was too short on my 2016.
Well Travis said it was not needed but I don't like the wire that tight .if I move the fuse box anymore forward the side cowling hits it.
Go on eBay, by a fan reverse harness, swap the pins in the harness and that will give you the extra length. I had the fan reverse harness installed until it turned out to be no help and just swapped the pins so it was normal.
Thanks for the tip but went on eBay and $40 to my door is a little much lol.wonder if I couldn't cut the wire and solder wires to make it longer and then heat shrink?
Is the Viper dif than the 7000?
I moved it and it has slack in the fan connector.
I also did mine as per the picture, my fan wires still reach. This is on a 16.5
I am pretty sure I was a part of that fuse swap. Easier than I thought it would, but not as easy as doing mine that was relocated.
Lol you were.
