'light load, cruising'Wasn’t it running the right AFR before the install, Dyno sheet for 270. The leanest was at 12.9 and that was at 5300 rpm and the richest was at 10.8 at 8800. 15.0 no expert but good luck !!!
If running a straight through open 2.5-3 inch exhaust I would get a bit of light popping when decelerating with regular maps.I agree, but shouldn't get a lean pop though.
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Tested the Hurricane tunes 240, 270, 300 and the closed loop system Saturday. Every pull, open and closed exhaust (Have the EVO Captain's choice muffler so I can have wide open at a touch of a switch). AFR's stayed around 11.7-11.9 every wide open pass.
The GAP data logging is nice and need to get an I-pad instead of using an I-phone for a dash...lol
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Because light throttle no boost conditions it should be searching for Stoich which is 14.64 to 1.IMO, hard to undetstand why a closed loop system like this would even permit an AFR that high.
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
I run TD’s Max Spool 17 290hp tune with a header and 3” exhaust 600 miles and no popping on decel.. I also have an O2 sensor, AEM wideband, aftermarket fuel pump, and fuel pressure regulator. AFR behaves where it should. I would be concerned with popping on decel...
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
like a back fire sound? If i am ripping hard on the sled, sometimes when i decel to a stop it back fires, but only once. and not every time.
Nothing very loud, maybe I could have used a better termlike a back fire sound? If i am ripping hard on the sled, sometimes when i decel to a stop it back fires, but only once. and not every time.
Ontarioviperxtx
- Oct 2, 2016
- Northern Ontario
- 2018 Sidewinder xtx
16 viper xtx se SOLD
08 nytro rtx SOLD
- Kirkland Lake
With your TD set up do you get the code on the dash until the sensor warms up?I run TD’s Max Spool 17 290hp tune with a header and 3” exhaust 600 miles and no popping on decel.. I also have an O2 sensor, AEM wideband, aftermarket fuel pump, and fuel pressure regulator. AFR behaves where it should. I would be concerned with popping on decel...
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
If you have the closed loop fueling option you will get the code at startup while sensor warms up, with both TD and Hurricane. If you run the afr module/sensor without the closed loop fueling option you will not have a code.With your TD set up do you get the code on the dash until the sensor warms up?
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
15 is lean , mine doesn’t go that lean at idle, 12.5 afr is we’re I’m cruising light good luck,'light load, cruising'
Ontarioviperxtx
- Oct 2, 2016
- Northern Ontario
08 nytro rtx SOLD
- Kirkland Lake
Ok I never get that code everyone talks about. With the closed loop system. Will have to look into itIf you have the closed loop fueling option you will get the code at startup while sensor warms up, with both TD and Hurricane. If you run the afr module/sensor without the closed loop fueling option you will not have a code.
I'm upgrading to this, so I will give feedback also on where the numbers are.15 is lean , mine doesn’t go that lean at idle, 12.5 afr is we’re I’m cruising light good luck,
Crossfire12
- Feb 13, 2017
Ok read it, I have never seen 15 afr . I guess it’s ok with the tune you have. It is new stuff.
justinator
- Mar 25, 2007
- Maine
Probably have different results with different sleds and different definitions of “cruise” . One sled/person may cruise at 80mph with 1/3 throttle and turning 6500 rpms with hardpack conditions at 5-6 psi of boost . Another sled is 1/2 throttle 80mph with 7300-7400 rpms and 8, 9 or 10 psi. Another guy considers “cruising” at 45mph and is seeing 2-3 psi at 5500 rpm. All 3 sleds have different load/ clutching/ gearing combinations which influence boost and running rpms and overall load on the engine and we get 3 different cruising afr’s. Not too mention that different tunes may have slightly different afr targets as well. Might be hard to compare from sled to sled imo.
- 6K
