Did you shorten the spacers on the throttle body clamps this summer?
I started with good intentions to do the clamp mod but never got around to doing it.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Ok, sounds good. Not enough snow here yet to ride.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Curious to know what gearing you are running?I started with good intentions to do the clamp mod but never got around to doing it.
Bob. You recently installed the bigger fuel pump... Correct?
LOL...I forgot about that!
Yes I installed Hurricanes High output Fuel pump and fuel regulator...I also rerouted the fuel return line to over the the fuel pump slipper.
All in the off season...maybe has something to do with over rev?
I'm thinking between the new fuel delivery and closed loop, your probly making more power or just plain more efficient.
I just wired up the bigger pump via bigger relay today. Not one bit of snow on the ground in western Maine to test.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
How much higher are the rpm's?
Dave at Hurricane explained to me that the closed loop allows the selected tune to perform at the performance level the tuner designed.
For example a 240 tune will actually make 240hp with an optimum muffler and intake.
The rpm increase varies, and I never data logged any rides, but the 240hp tune was over 100 rpm higher and the 270 tune was revving well over 200 rpm higher then last year, around where the 300hp tune used to run. I never ran the 300hp tune because the rpms were already high.
SledFreak
- Feb 7, 2005
- Ontario. Canada
So for me that does not mean much... ie... So if a tune is 270 SM and requires 3bar map sensor, CAI and blow off valve and you don't install the closed loop, but all other requirements are installed, then are you making the required 270?Dave at Hurricane explained to me that the closed loop allows the selected tune to perform at the performance level the tuner designed.
That's a question I am not qualified to answer but we all know any engine develops varying levels of power dependent on barometric pressure, temperature, altitude humidity, ect. The more components and electronics controlling and compensating for all the variables will allow for optimum performance and hp output.
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
Thus increased RPM from the added HP. Sounds like you'll be adding some weight to the clutch to bring the rpm down if you want to run the bigboy tune. This is a good problem to have! lolThat's a question I am not qualified to answer but we all know any engine develops varying levels of power dependent on barometric pressure, temperature, altitude humidity, ect. The more components and electronics controlling and compensating for all the variables will allow for optimum performance and hp output.
hman4
- Sep 22, 2014
- 2010 Apex, 2002srx, 2000 srx
Pull the throttle bodies if you do the mod, way easier to see whats going on. Still not an easy job but at least you know you have the clamp’s on right. I couldn’t see anything with out removing them.I started with good intentions to do the clamp mod but never got around to doing it.
Turboflash
- Mar 18, 2019
- Southern MN
Off topic to OP but I just did clamp spacer mod to 2 TCats this last weekend. There was 2 of us working together. With one holding up and out on throttle bodies, it was easy for the other to pull the spigots out making it unnecessary to remove them. Did each sled in about an hour.Pull the throttle bodies if you do the mod, way easier to see whats going on. Still not an easy job but at least you know you have the clamp’s on right. I couldn’t see anything with out removing them.
- 7K
