JPS
- Aug 23, 2014
- Clarks Summit, Pa
- 2018 sidewinder XTX, 2017 Viper XTX, 07 apex attack, 95 Vmax4
Thanks, you don't sound too promising. do you know some bad news?Hope you get it!
apexboyz08ltx15se
- Oct 17, 2014
- Michigan
- 2018 sidewinder 50th apexse2015
- Michigan
I heard they was backordered as well. After research i found it’s a aem x series inline part number 30-0310 found a few places online that have them in stock But doesn’t do any good if you don’t know how to wire it in and finding a wiring diagram is a act of god for the winder. I know it wires into the black plug where you flash the sled from. Obviously power and ground easy.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
I think the muffler Bung & Sensors are the problem getting right now.
I'm waiting myself
I'm waiting myself
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
I have all the stuff but waiting for snow gods to show!
no1b4me
The AEM module not purchased from a GAP dealer will not communicate with the ECU due to the proprietary AEM Can bus, called AEMnet.... This module needs to be flashed over to OBDII platform..... So it can communicate data over AC CAN bus....
Cheers
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Will the 02 module drain the battery if left plugged in?
no1b4me
It needs to be plugged into the accessory plug and it will not drain the battery.
The accessory plug works off the ignition key switch.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I know the accessory plug is keyed but what about the other plug in the harness to ecu.
no1b4me
Keyed switch
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
How do you get afr on dash ?
If you own a gap flasher you can change the setting as to wether it is afr or boost that shows on dash.How do you get afr on dash ?
NYTurbo
I don't think you need a flasher. If you have an AFR module if I'm not mistaken you will get AFR and Boost in the dash by selections on the cluster even with a single tune.
no1b4me
Data signal is enabled with any tune flashed to the ECU.
sx7001
- Jun 28, 2003
- Sidewinder
I have the closed loop setup and get both AFR and boost on the dash at the same time
0degC
- Jun 5, 2009
- Sudbury, Ontario
- 2023 SRX, 2017 XF 9000
If you have dash cluster flash it will be there easy to find. If you don’t have cluster flash it will be were hr meter is. In your phone app with flasher you can change hr meter to read ether boost or afr. This is TD anyway not sure if Hurricane different.How do you get afr on dash ?
