hman4
- Sep 22, 2014
- 2010 Apex, 2002srx, 2000 srx
Ya, sorry about the off topic. I was just reading through the post and was responding to an earlier post. Congrats on being able to do the job that quickly! I got it done but it was for sure not an hour job for me. Happy to be done with it.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
The rpm increase varies, and I never data logged any rides, but the 240hp tune was over 100 rpm higher and the 270 tune was revving well over 200 rpm higher then last year, around where the 300hp tune used to run. I never ran the 300hp tune because the rpms were already high.
Another reason why I bought the 02 module and sensor.
sx7001
- Jun 28, 2003
- Sidewinder
I have a couple hundred miles on my SW this season mostly lake riding. In the off season I did normal maintenance as well as installing Scott Taylor gears and the Gap closed loop flash.
I am now dealing with a significant over rev at full throttle on all my tune selections, even on the 240.
I have been adding weight to the daltons to get it back to the desired shift rpm.
Anyone else experiencing an increase in rpm after installing the closed loop?
My RPM is up with the closed loop also. Ive seen 9250. I had it running 9000 last year. No other change to the sled from last year. I will wait till the lake is ready to add weight. RPM is more consistent in different conditions for sure. Cruising A/F is high 14 low 15 now. I can hear a lean "pop" sometimes at cruise.
I'm looking forward to having a clean exhaust side lower panel!
NYTurbo
Lean pop is dangerousMy RPM is up with the closed loop also. Ive seen 9250. I had it running 9000 last year. No other change to the sled from last year. I will wait till the lake is ready to add weight. RPM is more consistent in different conditions for sure. Cruising A/F is high 14 low 15 now. I can hear a lean "pop" sometimes at cruise.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
So far it’s sounding like most are happy with the new system. Adding weight on the same tune you where setup for last year can only mean one thing!
SledFreak
- Feb 7, 2005
- Ontario. Canada
Ya 15.. seems a little high...My RPM is up with the closed loop also. Ive seen 9250. I had it running 9000 last year. No other change to the sled from last year. I will wait till the lake is ready to add weight. RPM is more consistent in different conditions for sure. Cruising A/F is high 14 low 15 now. I can hear a lean "pop" sometimes at cruise.
cjr
- Jan 28, 2018
- Old Forge
- 2018 Sidewinder 2021 sidewinder xtx le 146
Many thanks to Dave at Hurricane for helping me out with the install of the closed loop system. Simple install, I must have missed a step. Dave went above and beyond walking me through it. Many thanks, incredible customer support!
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
AF 15 a little lean be careful??
DooZ
Try to stay out of that throttle position if possibleYa 15.. seems a little high...
Turboflash
- Mar 18, 2019
- Southern MN
IMO, hard to undetstand why a closed loop system like this would even permit an AFR that high.
Nothing wrong with up to 15_15.2 at cruising/light load rpms
DooZ
I agree, but shouldn't get a lean pop though.Nothing wrong with up to 15_15.2 at cruising/light load rpms
Crossfire12
- Feb 13, 2017
I bet it will be the same, it is heat also my white ski is brown and it’s from heat cause you can’t clean it.I'm looking forward to having a clean exhaust side lower panel!
Crossfire12
- Feb 13, 2017
