InRBigness
- Apr 10, 2014
- winnipeg, manitoba
Your rails will fold up before that kit fails. It is truly a very well made piece of hardware.
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
I'm having trouble locating a Larson kit for my 14 RT-X.I have the Larson kit, you won’t break that one!
Call them directly. I have one on my 14 RTX.I'm having trouble locating a Larson kit for my 14 RT-X.
When the 19's come around for viewing, I would suggest taking at look at them. Sounds like the new SRX is running a new rear axle setup. Maybe the rails have larger slots along with a longer solid axle.....?I've had it with the 4 wheel axle kits! I broke the left side wheel off for the 3rd time in 3 years. 2 were turbo dynamics and this one is J T Racing Products. I keep shearing the bolt off in the axle.
This weekend was the weenie roast and it happened trail riding Friday Morning and caused me to scratch that sled for 2 days of racing. I have another 4 wheel kit and 2 try hubs but did not have them with me and we could not get the broken bolt out of the axle.
franklin
Larson kit is the strongest kit made, I machined the rails on my 2014 to except the 20mm axle that was in all other Yamahas took about 3/16 on top and bottom. Then for my other sleds I just got the Larson kit a little harder to install but way easier then machining the rails.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I've been late to the party in addressing the tri hub with a full blown solution, but its coming. I've always felt the solid axle was the way to go. I took note last year that the 18 SR venture had done away with the tri hub so I had been pondering a retrofit kit to use that set up. I'm assuming the 19's have that same set up. I'm working on a kit that will allow for use of a true solid axle on the 14-18 models. Have the whole kit envisioned. Modifications to rail will not require removal of skid. All you will need is a drill......stay tuned!
Wannaviper
- Mar 18, 2014
- West Gardiner, Maine
Does the Larson kit require removal of the skid?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Not that I am aware of. I noted not having to remove skid for my approach because franklin removed his and had them machined. I have an idea that should allow guys to mod the rails easily in their own garage.
Yamadog
Let me know when it's ready I will take 1 with 2 bags of chips pleaseI've been late to the party in addressing the tri hub with a full blown solution, but its coming. I've always felt the solid axle was the way to go. I took note last year that the 18 SR venture had done away with the tri hub so I had been pondering a retrofit kit to use that set up. I'm assuming the 19's have that same set up. I'm working on a kit that will allow for use of a true solid axle on the 14-18 models. Have the whole kit envisioned. Modifications to rail will not require removal of skid. All you will need is a drill......stay tuned!
- 35K
