just did mine,took 5 min,super easy,no more pressing brake to shift,best mod yet
monte1214
- Apr 20, 2005
- Durham Region, ON
- www.portperrysnowmobileclub.com
- 2017 Sidewinder LTX-SE
- How did ya do it?
![](/styles/admin.gif)
![](/styles/vip.gif)
yes please tell, I hate that thing.
![](/styles/TYLifeMember.gif)
i know on mine we just tied the activator in the applied position with a tie wrap. awsome not needing to step on rear brake to shift to reverse.
http://www.nyrocatv.com/techtip.cgi?viewtopic=344
do it like the last pic,just bend plate towards you enough for the pin not to catch,only have to remove left plastic,i used a small curved pry bar to remove nails
sx7er
- Jan 2, 2008
DO NOT DO THIS MOD... If you are moving EVER so slightly, you can cause catastrofic failure. If you dont believe me, i will show you picks of a engine case that had thrown reverse gear through it, due to a faulty middle drive gear. This is absolutely rediculous. The reverse lockout is there for a reason. Do yourselves a favor and put it back on. It may not be you using the atv all the time, the operator may not know.
- 10K
