hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Been getting requests for the header heat shields. With age they seem to crack and come apart. Yamaha updated them on newer models, but they seem quite pricey. Pretty sure I can offer better quality at a lower price, but just curious as to how many have had issues with them failing.
sideshowBob
I am still on my original heat shields on my 2019 X-TX but I ordered a complete spare set to have in my spares parts...it took almost a year to get them with the parts supply issues.
If I knew you could supply them I would have been interested in sourcing them from you.
Fords4life
- Dec 7, 2021
- South Dakota
Replaced a set last year, 2018 zr cat 9000
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I had one crumble and fall apart. Since my sled is a 17 model this is the updated recalled heat shield. So I am on 3rd heat shield.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
This one?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
They are without a doubt prone to failure. I'm on my second just this season and its already coming apart. I've seen some of the original Stainless ones hang in there pretty good, Some updated Alum ones also. But for sure there has to be a better way than the factory is doing them.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
Mine failed last year on my 2017.Been getting requests for the header heat shields. With age they seem to crack and come apart. Yamaha updated them on newer models, but they seem quite pricey. Pretty sure I can offer better quality at a lower price, but just curious as to how many have had issues with them failing.
swrtxlr
- Jun 29, 2016
- grantsburg
- 17 sidewinder rtx le
07 apex gt
00 srx olins
99 mountain max fully modded
gp 292
mod 292
I have over 11,000mi on the one that came on my '17 RTX LE with a brand new updated one still in the box.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
So was the original 2017 shield recalled or just updated?
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
Running three headers. 2 TD Gen 2. 1 TD Gen 1. I've had two heat shields burn almost through in a penny-size spot if the shield rests on the header for any significant time. Haven't had any outright "fail" though, and I've cut/hammer/dolly them all to fit the header with space.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I'm on my third one and have it held together with foil tape. This one didn't last a weekend before it cracked. And they aren't cheap.
PowderFalcon
Pinnin' it!
Travis, my failed 2 years ago. Another problem you likely know about is the flex pipe failing. When that happened to me, it burned a hole in the heat shield... and my gas tank! Was a less than ideal situation, i tell ya!
Brent
Brent
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
I've seen a couple break apart too
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
Just modify a Viper Heat shield and rivet it to stock header shield. The viper follows the same exhaust path and is solid aluminum instead of the tin foil they use on sidewinders. It needs to be modded slightly but works very well. There is a post somewhere here on forums showing pics of it, I did this to mine and its been flawless.
ghettosjeaffa
On my 2019 Sidewinder B-TX it cracked around the bolts which is nearest the tank.
- 32K
