ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Just weld it closed, and go fast.Same with 900t a wastegate adjustment is pain to do and clutches need a whole kit of tools to d to disassemble!!!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Not sure if this is the right place for this but I wanted to get the word out. CHECK ALL your hose clamps on the SRX. I have a brand new 2020 SRX that is leaking coolant. I will try to post a picture of the suspect hose clamp. I found three that were not tight, one was leaking. This is where the story gets interesting. To get to the suspect area, I removed the plenum and ran the sled to see where the leak was. As expected I got a code 22, warmed up the sled and then turned it off. I then tightened that clamp. That is when the sled started making an electronic tone of some sort. Lasted about 15 seconds then an audible click and then the noise stopped. Then about a minute later it started again, over and over and over. I put everything back together and ran the sled. The code 22 went away but the sled continues to make this tone, then it stops, then it starts. Doesn't matter if the key is on or off, doesn't matter if the kill switch is on or off or any combination of those. I decided to sit on the sled and think....guess what happened....the pitch of the tone changed, so I stood up, tone stopped, I sat down, tone started again. I will try to post a video. Is this sled possessed or what? Any ideas would be greatly appreciated and if you bought one of these I highly suggest you check every hose clamp. Frustrating! Clamp is right below flashlight. View attachment 150327
Coolant leaks, nothing new. Should have come with constant tension hose clamps instead of worm clamps. Check all your clamps even the ones under gas tank thru tunnel.
Loosen your gas cap up and let sit, I bet your electrical noises will go away. Dont forget to tighten it then...
Enjoy your new sled!
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Top of page you'll see a VIP link.Thanks for the post Mike, glad to see you're still wrenching in Welch. We met years ago, shortly after your Warrior track incident. You did some extravert drivers and a track for me, nice work btw. So how do you become a VIP member, would love to get a manual on this thing so I can get educated.
M
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Do not turn the key on with sensors unplugged. That’s a sure way to trip a code.
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
It’s very dangerous. Best thing to do is drop it off with me. I’ll ride it for approx 1000 miles to ensure you are completely safe. You’re welcome!
Signed,
Mr. Helpful
Signed,
Mr. Helpful
Crazy Canuk
Haha, do you mean the ones that would cause the puddle under the 2020 Ltx Le I just picked up Friday? Wasn't too happy when i poked my head in the trailer earlier to see how she was doing. I figure it is her way of reminding me to check every clamp and bolt on her before I hit the snow.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
I like that you refer to your sled as if it’s female.Haha, do you mean the ones that would cause the puddle under the 2020 Ltx Le I just picked up Friday? Wasn't too happy when i poked my head in the trailer earlier to see how she was doing. I figure it is her way of reminding me to check every clamp and bolt on her before I hit the snow.
These High Maintenance machines are akin to.... well ya know those super hot, high maintenance women we used to date back in the day.
Dam they are fun 2 ride!!!!
Turboflash
- Mar 18, 2019
- Southern MN
LOL!I like that you refer to your sled as if it’s female.
Crazy Canuk
LOL, there are some that like 'bolt on' accessories for more than just their sleds.I like that you refer to your sled as if it’s female.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Hot rod package! Big top end with little bottom end!
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Ok you guys have inspired me to change my avitar!Hot rod package! Big top end with little bottom end!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Clutchmaster, what is the offset on that belt in your avatar?
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
Does she by chance frequent the Birch Lake Bar? LOLOk you guys have inspired me to change my avitar!
1Lcheapo
- Jan 27, 2009
- Live in Milwaukee, WI
- 2017 SIdewinder LTX-LE
- Ride out of Harshaw, WI
I would say not a chance!!!!!
