![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
krm
- Apr 22, 2016
- ny
CorrectSo the 89.99 tool there shown, is the one specifically for the Sidewinder clutches?
HURRICANE
The hurricane clutch alignment tool works on all sidewinders
WinterWolf
- Mar 25, 2017
- Connecticut
Just watched your video....nice job.
So just a tiny bit of play is ok..but any more than a tiny bit means the clutches aren’t centered...if it fits nice and snug(zero play), is it even better??
I think I’m gonna buy it from you Dave. Can I call you and do it over the phone..or do you prefer people do it on line?
krm
- Apr 22, 2016
- ny
It's not about being centered ,It's about the correct off set that changes as the motor is loaded and shift occursJust watched your video....nice job.
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
I don’t see how this tool does anything more than give you a gauge to set offset to ~58mm. What am I missing?It's not about being centered ,It's about the correct off set that changes as the motor is loaded and shift occurs
Post corrected.
HURRICANE
Is 68mm the correct offset?
HURRICANE
This tool sets the correct offset to insure that the belt runs perfectly strait when it’s supposed to.
krm
- Apr 22, 2016
- ny
Not for all Mines 57.83 mm no belt issuesIs 68mm the correct offset?
hman4
- Sep 22, 2014
- 2010 Apex, 2002srx, 2000 srx
I thought offset was supposed to be like 58.mm not 68. mm. Unless you have some type if indicator and gage block setup your just guessing if you think you know where you are down to the .1 mm’s. ( a sheet of notebook paper is thicker than that.)
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Yep. Sorry for that I’m on my phone and didn’t notice I fat fingered it. I had 2mm milled off my secondary shaft so I can get offset to 57.5mm to start with this new sled.I thought offset was supposed to be like 58.mm not 68. mm. Unless you have some type if indicator and gage block setup your just guessing if you think you know where you are down to the .1 mm’s. ( a sheet of notebook paper is thicker than that.)
he was asking the question...like how do you know thats the right number...he's selling a tool that puts you in the right number which is reserved..
krm
- Apr 22, 2016
- ny
That's why all are at a different spec .Sheave thickness on the drive ,bearing set on the driven and the back side of the drivens are not all the same.he was asking the question...like how do you know thats the right number...he's selling a tool that puts you in the right number which is reserved..
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Yes,works great,i ground 2mm per his tool,and all has been good.That is right
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Yes,that is the tool,its simple to use.Was just on his site..found a clutch alignment tool, but it just says to help align your Yamaha clutches(nothing about specifically the Sidewinder??). Is this the one you’re talking about for the Sidewinder?? It’s 89.99 US dollars. Or is there another one specifically for the Winder.
And no video...it’s gone. If anybody has the video, or knows where to find it, I’d love to see it???
alpineviper
- Aug 24, 2014
- Alpine Turbo Viper
how are you guys grinding them down? or are you taking it somewhere?
- 11K
