How much oil does a 2016 viper take?
CooperT
Age
40
Fergus, Ontario
Canada
2018 LTX DX
2016 RTX SE
Doing the first oil change and I've got 3.6L in there so far and the dipstick still says it needs more. Manual says 2.8L. Just a little confused here...any help is much appreciated!
pretty sure around 3 ,5 to4 liters with filter change! Look at your manual again I think it's 2,8 in the tank then start for 1 min then add more to tank to reach proper level!
just a heads up while your doing the oil change make sure the oring on the old filter came out! seems like they stick in there when doing first change
Ya that would make sense. That was the first thing I noticed. Filter was a bugger to get off as well. Thanks Marc!
Ya both ours and my buddies new 16 were hard to remove and we all had the o ring stick! I don't think they lub the o ring from factory
Just did mine and it took just over 3 quarts. And yes the filter is a pain in the arse to get off. I also love the soft screws that seem to strip the heads when any amount of torque is put on them.
Well I just let it idle until rad fan came on then checked oil level 30 secs after. It's almost at the top line. I've got 3.6L in it. I may take a 100ml out to get it into the middle of the stick.
I've done mine twice and both times took bout 3L right on the nose. I've asked around and said its normal. Was concerned but have 2500 miles on now with no issues.
the dip stick style oil tanks hold 1/2 litre more than the sight glass
Make sure the o ring does not stay on the block. Very common.
I used 4 l of oil. Right at the full mark.
You guys are draining the engine right? There is about a half quart in the engine that needs to be drained as well.
Yup, drained engine. Removed filter and the black O ring that was stuck to the block. Then drained tank. Makes a mess too...I'm just below full mark at 3.6L. Warmed engine up until rad fan came on, then shut sled off and waited 30seconds to check oil level. Checked 3 times really quick...just below full mark.
Yes it does! Just wanted to make sure the engine was empty. Here is my fix for the mess, it slides through the running board and up into the footwell. Works pretty good for homemade.
Here is my homemade fix. Half a power steering fluid bottle. Also I've seen half a yamalube quart works. No mess.
