DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
The first pic shows the stock 35 next to the 35/39 reverse. Second pic shows the stock 35 next to ulmers helix.
I'd like to know how to measure the angle? Ulmers helix is a progressive and much steeper than stock.
With this helix I'm running 78 grams on my STMs with PT CAI tune. Pulls right up to 8900 rpms, haven't been able to test other than a couple 300' bursts to see how the rpms hold but I like how it feels down low.
I'm not sold on all the hype of reverse angles and can't wait till my run at work is over so I can do some testing.
Derek
Derek
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
That progressive of Ulmers would work well with a early spool type tune.
DMCTurbo
- Nov 12, 2005
TD Max Spool 17That progressive of Ulmers would work well with a early spool type tune.
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
Derek.....Measuring the true angles of a helix is a lot simpler than you'd think. All you need is a flat surface, a hex head nut and a angle finder: https://www.weselltools.com/small-p...k7DKwTd0rMQiZVotsauvW-jXq40plug0aAjQkEALw_wcB
These angle finders are pretty easy to source at most auto parts stores and hardware stores and are pretty cheap.
1. You need to place the helix on a flat surface with the ramps facing up.
2. Place the hex head nut anywhere on the helix ramp where you want to measure the angle. Make sure that one side of the nut is making full contact with the ramp surface that you want to measure. The starting angle would be the very tip of the helix where the rollers or buttons make contact with the ramp under no load.
3. Lay the bottom of the angle finder on the very top of the hex head nut opposite the side of the nut that's making contact with the helix ramp. Take a look at the tip of the needle of the angle finder and you'll find the helix angle.
There's no voodoo to measuring the helix angles.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
DMCTurbo
- Nov 12, 2005
What app?
DMCTurbo
- Nov 12, 2005
Thanks great info!!Derek.....Measuring the true angles of a helix is a lot simpler than you'd think. All you need is a flat surface, a hex head nut and a angle finder: https://www.weselltools.com/small-p...k7DKwTd0rMQiZVotsauvW-jXq40plug0aAjQkEALw_wcB
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
What app?
Pipe bending app called IBend pipe.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Did Ben post dyno sheets of where the boost comes on? I was looking but never could find where his boost comes on.TD Max Spool 17
Dan
- 16K
