kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
Anyone have a how to on changing the secondary rollers?
Sent from my SM-G920W8 using Tapatalk
shadow44
Take it to the dealer and tell them to fix it under warranty
WINDER1987
What will the dealers put in it as a replacement roller though ?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
set your parking brake..loosen the roller pin set screw....take a box end of a combination wrench to the helix bolt...push on the wrench and the helix will start to move (twist) to relieve pressure....hold with pressure relieving to do the swap....now the helix is off the roller and the pin can slide out...out comes the roler....in with new roller...back in pin....reinstall set screw....loosen brake rotate clutch...repeat process
or you can pull the clutch...pull the helix and work at your leisure.
done dooin'_winder up
- Dec 6, 2016
- saegertown pa
- 2017 sidewinder stx 137 dx
thank youset your parking brake..loosen the roller pin set screw....take a box end of a combination wrench to the helix bolt...push on the wrench and the helix will start to move (twist) to relieve pressure....hold with pressure relieving to do the swap....now the helix is off the roller and the pin can slide out...out comes the roler....in with new roller...back in pin....reinstall set screw....loosen brake rotate clutch...repeat process
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
1998 MACH-Z
Thanks SJ I have a set of torlons on order. If my dealer will replace with those they can do it. If they are just gonna put OEM rollers in I'll do it myself
dsimonRX1
- Dec 17, 2003
- Cascade,Ia
- www.american-iowa.com
Where can I buy the Torlons from? Part number?
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
1998 MACH-Z
From cat. The part number is listed in the thread about the flat spots. Ulmer also has an improved roller available I believe
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Thanks steve. Have to go to cat tomorrow. I'll see if they have the rollers in stock. If so, I'll grab them.
silverram323
- Mar 24, 2013
- Jodrell St, Cambridge, mn 55008
- beyondsynthetics.net
- 2017 Sidewinder XT-X 141
Are you guys talking about these?
Sent from my iPhone using Tapatalk Pro
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
My thoughts exactly!Take it to the dealer and tell them to fix it under warranty
- Dec 6, 2016
- saegertown pa
pulled clutch off but not apart. hardest part of changing rollers was cleaning the red loctite out of roller bore so the pins would come out.
mplourde
Will install 3 of them tomorrow and try it right after ...
Envoyé de mon SM-G935W8 en utilisant Tapatalk
ssgzag15
Who said the stock ones were supposed to roll? they are merely round sliders, they have to 'flat spot" to wear together evenly.
sgauthier
- Mar 5, 2009
- southwest, Ontario
- 2011 Apex XTX
You're joking right.
the whole idea behind the rollers is to let the clutch open and close quicker/ faster without friction so it back shift faster. If they weren't supposed to spin or turn then why would they use rollers instead of the regular slider buttons?
