we have very little snow so cannot test turbo but would love to see a video of some wheelies to heighten the anticipation
This is an Mpi and no wheelies because I coupled the rear suspension but it is fast and skis are a ft off the ground should keep you going for a bit.
https://www.youtube.com/watch?v=pOztLtIkIYE&feature=youtu.be
kodak
yamadog all your posts and vids make me want to spend more money seems you have that sled dialed in really nice
It took a long time and a lot of $$$ but I finally have the power I was looking for in this sled. I am still working on the handling. The XTX is quite a challenge to get through the tight twisties. With the coupled rear I am finally able to keep the skis closer to the ground but you better be ready when the turn shows up !!!!!
from turn to turn there is nothing I have ever ridden that with stay with it. I have had a rear mount RX-1 Turbo that I thought was fast but it did take almost 40 to 60 ft for it to get to stock HP then it would come on. This thing from a dead stop will pull your shoulders out the sockets. I have ridden S/C nytros and they pulled but had a lot of trouble with track spin even on the XTX versions.
I really want to find a reflashed xf 1100 to see where this thing is at. I ran 2 of them last year and had no problem with them but they said they blew the takeoff and had bad track spin, but refused to line up a 2nd time. This is a different animal now at 12#'s and with all the pics. at 12#'s I am getting a little spin which is causing the rev limiter to bang a bit but am afraid at this point to put more weight in it cause I run most of the time at 9#'s of boost and it would cause that to be way over clutched.
kodak
when installing the turbo kit did anyone install a hose to the blowoff valve on the bottom of the new airbox ?
titanrcr
- Jan 3, 2011
- Old Forge, New York
- 2019 Sidewinder LTX LE
2015 Viper LTX SE
2011 Apex
Yes sir, I mentioned that in my "Hurricane 190 Review".when installing the turbo kit did anyone install a hose to the blowoff valve on the bottom of the new airbox ?
kodak
I need some snow starting to lose my mind overthinking I already have it hooked up
tator
braaaaaaaaaap wheeeeew! thats the sound a turbo makes.
kodak
Hey guys just wondering what all you guys are running for clutching on hurricane 190 kit . I have the hurricane clutch kit with purple secondary spring wrapped 0 and 1 and supertip arms with hurricane setup 4 washers and I was running 8300 rpm max rpm but hitting rev limiter at hole shot I put in a pink pink pink primary spring and now I have 8600 rpm max but still hitting rev limiter at hole shot another fellow Ty brother with very similar setup has same issue and added a washer to the heel but dropped max rpm and still hit rev limiter. Any suggestions.
YAMMAROB
- Feb 11, 2013
- Dyer, IN
- 2014 XTX Viper Hurricane Turbo,
2015 MTX Viper
Sons: 2009 Phazer Suprecharged RTX Streched to 153
I also am running daves kit with the purple spring at 3-3 banging rev out of the hole but mine is a xtx with no studs. Max rpm is 9050 added 1 washer to the heal and now banging at mid range not out of the hole the only problem I have is having to let off the gas to steer........
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
Hi guys, i recommend adding wieght to tge heel of the cam arms until it stops hitting the rev limiter at take off.add wieght to the middle of the arm if hitting the rev limiter after 100ft or so.
kodak
I would rather hit limiter at mid than hole shot rev limiter is fooling up my wheelies and cat walks
kodak
Wow customer service just doesn't stop with Dave . Great team to deal with . Thanks hurricane for making us faster keep it up.
Dave are you going to have a spring snow check special at all?
YAMMAROB
- Feb 11, 2013
- Dyer, IN
2015 MTX Viper
Kodak how do you like the 38" front end?
YAMMAROB
- Feb 11, 2013
- Dyer, IN
2015 MTX Viper
Thanks Dave will add some to the middle got my boost gauge back from AEM and Im showing 6 and a flash of 7
