1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Chaincase cracked and leaking oil.
Have new one on order.
I just don't get it.
No failure inside case.
Must have been that dang set of g outs that bottomed out the front end at.
Landed in the face of the 4th one at speed.
Using the chaincase as part of the chassis, I've felt they were lacking in material here. I've seen a few like this.
gamemaster
where is it cracked?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Above and below the bolt that threads into the case on the aft side.
gamemaster
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Yes and below the bolt also.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Both circled areas are cracked.
Trailleader
- Feb 9, 2023
- Wausau Wi
- 17 9000 stage 4
Is that 13001 miles? Lol
I have a couple if you need to get going
You have to say the magic word though
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
And a 1/2.Is that 13001 miles? Lol
Thanks for the offer!
I have one on order but it has not shipped yet.
We are close to the end of the season so I will ride my Nytro thru the spring riding.
My plan is to do a full teardown and rebuild of the driveline this summer.
Also ordered a new brake caliper assy.
Trailleader
- Feb 9, 2023
- Wausau Wi
- 17 9000 stage 4
Any thought on going to the belt drive?
Big Ugly
- Jan 20, 2015
- Sidewinder 50th Anniversary
Chaparral SSX (dirty bird)
- Middle River MN
Sounds like a fabulous idea to meAny thought on going to the belt drive?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I still want my reverse.Any thought on going to the belt drive?
Don't know how long belt drive will last trail riding and being in the elements.
I have noticed sand in my belly pan after removing muffler. Must be from dirty snow.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
When I see those speed bumps in parking lots I speed up to hit them, #*$&@ blew a tie rod, smart?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I run a bead of silicon along the gaps in the plastic panels where they overlay.. This helps to keep sand and crap out. If you riv nutted your lower panels you probably know where the gaps are.. I simply peel the silicon and run another bead after putting lower panels back on after oil change etc.I still want my reverse.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
I just had it happen to 2 winders exactly same area
One with 17000 Km the other with 18000km
Must be what 74nitro said week area and flex also 2 yrs ago happened to another one I work on.
I think with tunnel flex and age this is gonna happen IMO.
- 8K
