This is good info on any kit to be sure your spring is set right... check it out.
https://www.facebook.com/video.php?v=723142517766251&fref=nf
Mountaintech
Yeah, the Cat purple spring (EPI P/N ACSS-5 ) takes 2 strong hands to install!
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
he recommends moving it from 3-3 to 1-0? Any turbo owners out there comment on this set up?
Mitch Desorcy
MAX PRO
- May 6, 2014
- Winnipeg Manitoba
- 2014 Yamaha SR Viper LTX SE
Wouldn't wrapping the spring over 1/3 over change your lbs? 3-3 means you are at 60lbs and if you wrap it 1/3 to the next holes on the helix change the pressure? I have the same clutch kit and did wrap it over 1/3 turn. Seems like a lot of pressure.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
It's crazy tight! Be careful twisting that cat green..
Mitch Desorcy
MAX PRO
- May 6, 2014
- Winnipeg Manitoba
I can't see twisting it that much be any good for upshift. It will rob horsepower.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
If you wrap it 3-3 and truly put a 1/3 of a turn of twist on it, then it is very very tight, will raise RPM, be hard on buttons, and belts as well.
The 0-1 setting is a overall better setting and will be much easier on both the clutch components and the belt. You do not have to change your setting, it's just my suggestion.
In the video there is no wrap at all. Thats the problem and what he is explaining.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Yes, that is what I was showing in the video, to be sure you actually tension the spring, instead of just push the helix straight down onto the studs.
Joshua
- Apr 14, 2010
- Newfoundland
- 2018 Yamaha Sidewinder BTX LE 50TH
I may be missing something here, but didn't you say on your Facebook to set the secondary to 0- 1?If you wrap it 3-3 and truly put a 1/3 of a turn of twist on it, then it is very very tight, will raise RPM, be hard on buttons, and belts as well.
The 1-3 setting is a overall better setting and will be much easier on both the clutch components and the belt. You do not have to change your setting, it's just my suggestion.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Yes, it was my suggestion to go to a 0-1 setting, I apologize as I mistyped it in my above post.
Joshua
- Apr 14, 2010
- Newfoundland
Thanks. Maybe a dumb question, but when you say 0- 1 is the "0" on the helix and "1" on the secondary?
- Apr 17, 2003
- Menno, SD
- Menno, SD
Joshua
- Apr 14, 2010
- Newfoundland
Thanks a lot. Now can you make it snow here in Newfoundland???? LOL!!!!!!
nope but i bet he is working on it
- 39K
